It is currently Mon Aug 04, 2025 3:54 pm
PostPosted: Sun Jul 22, 2012 1:01 pm
My originall SU fuel pump (1970) on my Mini Van is failing and rather than putting in some new points I was thinking of converting to a solid state option sold by Mini Spares
http://www.minispares.com/product/classic/AUF214MS.aspx
Alternatively, I was considering another Pierburg rollervane pump which I have on my SD1. These are rated at 3.9 -5.5 psi, deliver 130 litres per hour (34.34GPH), self priming, lift capable, no return, very quiet, weighs 0.5kilo.
Is this too much pressure for HIF44 feeding a 1360?
www.injectacarb.com.au
Slide
1965 Mini Van (1360)
1970 Mk2 Cooper S (1310)
1978 Rover SD1 V8 (4.6)
PostPosted: Sun Jul 22, 2012 2:49 pm
I use the Facet electronic one, it feeds my 1360 with 45 Dellorto just fine..
It worked fine with my HS6 SU on the 1412 as well.
http://www.ebay.com.au/itm/ws/eBayISAPI ... 691_262721
PostPosted: Sun Jul 22, 2012 3:33 pm
They look very compact. Some folk reckon Facet pumps are very noisy, producing a constant clatter from the rear subframe, but I've not tried them so don't know. Maybe they're referring to the larger Facet competiton cylindrical type pumps.
Slide
 Post subject: Electronic Fuel Pumps.
PostPosted: Sun Jul 22, 2012 3:50 pm
I sell electronic Fuel Pumps ideal for Minis complete with Rubber mounts "so they don't make noise" They have between 2.5 and 4.5 psi pressure. $35.00 posted. If interested contact me.
"Let us remove your "SHORTS"
PostPosted: Sun Jul 22, 2012 4:00 pm
I mount them using a front (square) exhaust mount. The 2 holes line up.
Drill 1 hole 5/16 dia in the subby, fit a 5/16 UNF nyloc nut, and you are done.
