It is currently Tue Jul 22, 2025 5:20 pm
 Post subject: good distributor
PostPosted: Wed Aug 08, 2012 7:32 pm
thinking of changing my standard dissy, what are everybody's recommendations??
engine is a 1275 cooper block, twin 1.25" carbs, and has electronic ignition, not sure what cam etc, does have 1.5:1 roller rockers however
cheers guys
PostPosted: Wed Aug 08, 2012 9:27 pm
I like modified Pulsar dizzys, they are more reliable than electronicked Lucas ones. They don't seem to let the smoke out if you leave the ign on.
Hitachi smoke = stronger magic than Lucas+Chinese module smoke. :P
PostPosted: Wed Aug 08, 2012 9:51 pm
Look through simonbbc's range on ebay
PostPosted: Thu Aug 09, 2012 5:39 am
do i need vacuum advance or can i go without?
PostPosted: Thu Aug 09, 2012 8:32 am
Vac advance is just an economy device- at full throttle they do SFA.
Most small euro performance engines of the 60s & 70s don't use them (eg. Cooper S, Alfa Romeo, Fiat, Lancia, etc).
The smog Minis sold here from 1976-1978 didn't have any vac advance, either.
You can't easily run it with a Weber or Dellorto carb, they have no suitable connection for it at the throttle butterfly.
Racers remove it as it's just something to go wrong, and the breaker plate and timing is more stable without it.
PostPosted: Thu Aug 09, 2012 9:10 am
http://www.performanceignition.com.au/s ... stributors
Have a Nice Day.
PostPosted: Thu Aug 09, 2012 6:33 pm
+1 for Scorchers
Slide
1965 Mini Van (1360)
1970 Mk2 Cooper S (1310)
1978 Rover SD1 V8 (4.6)
PostPosted: Thu Aug 09, 2012 7:08 pm
850man: just ask for scorcher ignition kit to suit a 1275 with electronic ignition??
PostPosted: Fri Aug 10, 2012 8:53 pm
+1 for these.
Alec
PostPosted: Fri Aug 10, 2012 9:17 pm
Yes, they sell both points & elec types. Tell them what engine size & cam spec and they will make a new Bosh distributor with an advance curve to suit your engine.
Have a Nice Day.
PostPosted: Sat Aug 11, 2012 5:46 pm
Online
Vac advance is just an economy device....
Yep that's about it ... if you're happy to pay the equivalent of $2/l for fuel, you don't need one...
Cheers, Ian
PostPosted: Sat Aug 11, 2012 8:58 pm
hey are the USB tunable 123 dizzys any good?
i mean for just bolt it in, connect leads then get it prof tuned?
1969 Blue Mini K, 1330cc, Weber 45, polished aluminum roll cage, Race seats, 4 point harness, full rewire incorporating 8 fuses, 6 relays and new headlights :) just needs tyres front shocks and a windscreen til re-register
PostPosted: Sat Aug 18, 2012 6:00 pm
Any opinions on the Aldon yellow dizzy? My engine is a fairly similar spec to the OP, bored to 1310cc, twin 1.5" SU's, mild road cam 1.5:1 roller rockers etc.
Cheers, Matt
Don't be fooled, Gruhms is not my real name.
Users browsing this forum: 1071 S, Bing [Bot] and 86 guests
