It is currently Mon Jul 21, 2025 10:12 pm
PostPosted: Sat Jun 04, 2005 10:28 am
while driving Herman he just turned off - no acceleration with throttle
as it slowed down, the gears downshifted
____________________________________
jumped out, changed dissy - nothing
rules out condenser, points,
changed coil - nothing
rules out coil
checked wiring - nothing loose
checked float bowl - no sign of water
_____________________________________
when you turn him over, he turns and turns. the rotor also turns
but theres no ignition
battery is good, good turn over speed
any ideas?
thanks in advance
Inconspicuously Conspicuous
PostPosted: Sat Jun 04, 2005 10:34 am
Are you getting fuel into the carby? Pull the fuel line off the carby and grab a 1.25l coke bottle and stick it in that then turn the motor over a few times and see how much comes out.
PostPosted: Sat Jun 04, 2005 10:53 am
Do you have spark going to the Plugs
And it does sound like a Fuel Issue :?
PostPosted: Sat Jun 04, 2005 11:02 am
thanks boys ill try weed out the problem
problem is, car is half an hour away :shock:
PostPosted: Sat Jun 04, 2005 11:09 am
30mins driving or pushing :wink: :lol:
PostPosted: Sat Jun 04, 2005 11:12 am
thirty minutes away driving :lol:
took a fair bit pushing to my friend's house nearby
PostPosted: Sat Jun 04, 2005 2:10 pm
Fuel.
If u got spark its fuel.
PostPosted: Sat Jun 04, 2005 6:45 pm
Josh n I squeezed out the problem
had spark
turned over
put fuel down the air intake
soaked up the float bowl fuel
and away it went
