It is currently Sun Jul 27, 2025 3:00 pm
Post new topic Reply to topic  [ 34 posts ]  Go to page 1, 2, 3  Next
 Post subject: Gearbox casing numbers
PostPosted: Thu Sep 27, 2012 10:41 am
Folks,
I have what I thought was an S box. I've had someone send me a message saying they're of the view it is not based on the casing number.
Casing number is 22A1288.
I have no desire to sell someone something that is not what I think it is.
JC
PostPosted: Thu Sep 27, 2012 11:08 am
http://www.ausmini.com/forums/viewtopic ... cce8617911
It could be a transitional mk1 s box from around 1968.
If it is the other stamped in number starts with 12FAxxxxx
See the above thread!
PostPosted: Thu Sep 27, 2012 11:17 am
http://www.ebay.com.au/itm/Morris-Mini- ... _500wt_922
It appears correct, except the outputs should be hardy spicer, all the numbers are Cooper S.
PostPosted: Thu Sep 27, 2012 11:36 am
Not all Mk1 S boxes got Hardy Spicer outputs. The 1965-66 ones had rubber couplings.
PostPosted: Thu Sep 27, 2012 12:14 pm
Do all Cooper S boxes have LSD's or are they an option?
If its got tits or wheels its gonna cost you
1973 Solid side Leyland Mini Panelvan 1100 in Hairy Lime(Elma)
1976 Clubby project in progress
1966 Morris Mini Deluxe in need of a full resto
1971 Mini K Garden Art
PostPosted: Thu Sep 27, 2012 12:22 pm
None of them
1964 998cc Cooper
1971 Mini K x 2
1972 Clubman GT
PostPosted: Thu Sep 27, 2012 2:14 pm
Panthersteve wrote:
None of them
LSDs were available back then for improved production racing as a Special Tuning part.
Not as a factory fitted option.
PostPosted: Thu Sep 27, 2012 4:25 pm
yes , just as the good Doc suggests,,, very early "S" boxes had 3sync & rubber unis,,,, plus that Ley-gear is definately very early "S" for a fact
Matt
PostPosted: Thu Sep 27, 2012 5:01 pm
I thought all the early mk1 s boxes had the 333 case while the very late mk1 transitional boxes were 22a therefore it should have the hardie spicers with the 22a identification.
PostPosted: Thu Sep 27, 2012 7:08 pm
Would it help to also put up the teeth count for the pinion and crown wheel? That may tell people if it is an S ratio diff.
PostPosted: Thu Sep 27, 2012 7:12 pm
18/62 is a 3.444 ratio.
PostPosted: Thu Sep 27, 2012 7:39 pm
Are you the original owner of the box? If not then who knows what it's history is. The case may not be original, I always learnt to tell by the lay gear anyway. I have a few casings that share numbers with mk2 s coopers (from my research) but the laygear tells of their pedestrian nature.
Are hardy spicer unis easy to swap over? I know pot joints use a different side cover.
PostPosted: Thu Sep 27, 2012 7:42 pm
Pot joints can use a std side cover. But the diff shafts have circlip grooves.
To change to hardy spicers you need S side covers (as the bushes & shafts are 1/8" bigger), S diff output shafts, and S drive flanges & bolts.. New, these bits are NOT cheap.
You can bore some of the Oz made side covers to fit the S bushes as these covers are thicker.
PostPosted: Thu Sep 27, 2012 7:52 pm
Lay gear is 22g232
PostPosted: Thu Sep 27, 2012 7:54 pm
How do I determine that?
