FNQ wrote:
Hi
Going to try doing up the old contessas. (doc.. show pictures of your recent work , as i am looking to do a home black spray can also)
here's a pic-
The LH wheel is an old one, paintstripped and repainted. Have 3 more the same. The nuts are the SS ones.
Paint used was epoxy primer, then VHT's `quick coat' gloss black acrylic enamel. It's durable, dries fast with great gloss. They got 4 coats. 1 can did all 5 wheels.
The RH wheel is a NOS one, had no washers in. I made 4 new washers then painted it. It has a bigger centre hole. Will be used for the spare.
All wheels were wet sanded in a lathe with 600, then 1200 wet/dry paper, I've not hit them with the Mothers mag wheel polish yet.
[edit] Any kerb rash on the 4 old ones was machined off first.
DrMini- 1970 wasaMatic 1360, Mk1S crank, 86.6HP (ATW) =~125 @ crank, 45 Dellorto (38 chokes), RE282 sprint cam, 1.5 rockers, 11.0:1 C/R.
