It is currently Sun Aug 03, 2025 6:26 am
 Post subject: Rear Trailing arms bolt?
PostPosted: Wed Jan 09, 2013 1:58 pm
Die Die Die!!
as i was dismantling my rear trailing arm i couldnt help but notice the difference in the threads for the shocker bolt,
which one is the right bolt? and are they replaceable ?
PostPosted: Wed Jan 09, 2013 2:03 pm
i can see that they are moke arms :D the one at the top is the right one, the bottom one is a lot bodge, un-sure on how to replace them though.
PostPosted: Wed Jan 09, 2013 2:04 pm
The coarse one is a ring-in, looks like somebody has stripped the original thread, and either turned down the diameter or replaced it.
PostPosted: Wed Jan 09, 2013 2:09 pm
This thread has the Moke forum's suggested approach to this problem. Follow that if you wish.
http://www.mokesinc.org/index.php/topic,3869.0.html
(Posted in the interests of helping someone out. Not intended to start another flame war from people who don't like the Moke forum!)
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Wed Jan 09, 2013 2:21 pm
Die Die Die!!
thanks for the link ,
so just get a 4" 3/8 UNF HT bolt and then screw it into the arm itself untill tight, or drill a hole through the arm and use a nylock on the bolt ?
that sounds easy enough..
PostPosted: Wed Jan 09, 2013 2:25 pm
Not sure that you need to drill the thread out, as I have not done this mod to my Moke (yet).
Brett Nicholson
1966 Austin Mini
1973 LR Series 3 88
Users browsing this forum: No registered users and 68 guests
