It is currently Tue Jul 22, 2025 5:58 pm
 Post subject: Fan on backwards
PostPosted: Sat Jan 12, 2013 3:11 pm
ok so i have found my weakness ..
i can't for the life of me tell if my fan is on the wright way ..
i thought it was fine buyt now after looking at the Cooper on the shannons auction im all confused.. would this explain why the Fan is so noisy ?
Beanie
I am the son of the STIG
HOTBRICKS
http://hotbricks.org.au/
'65 NCF MINI.....
PostPosted: Sat Jan 12, 2013 3:14 pm
The reason its noisy is because its a 4 blade fan.
PostPosted: Sat Jan 12, 2013 4:07 pm
There's a nice explanation of the noise levels for the various types of fans here - http://www.minisport.com.au/category3_2.htm
PostPosted: Sat Jan 12, 2013 6:12 pm
I take exception to the 1st line in that Minisport ad, sure they were designed for Australian conditions:
In 1965 we got a new improved radiator with 16 gills (fins) per inch.
Was still a 3 core but cooled much better than the previous ones.
As for fans, I believe the original 16 blade metal fan on our cars was an Australian design, then adopted by the Poms.
IMO it's still the best/quietest for a road car. :wink:
Cooper S overheating in traffic? that's a /flame subject for another thread.. :lol:
PostPosted: Sat Jan 12, 2013 7:45 pm
I think the four blade fans will only go on one way?
And yes they are very noisy.
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Sat Jan 12, 2013 8:51 pm
Yes, the 4 blade can only go in one way.
PostPosted: Sun Jan 13, 2013 10:30 am
Ditch that noisy thing, sounds terrible!
:shock:
PostPosted: Sun Jan 13, 2013 12:13 pm
Cheers Guys i was pretty sure that it was correct...
but i thought i best just to check ..
would a six blade fan be better for air movement ?
just trying to chase a heating issue,
Beanie
HOTBRICKS
'65 NCF MINI.....
PostPosted: Sun Jan 13, 2013 12:22 pm
I would look at whatever is causing the heating issue. The fan is not causing it to overheat.
PostPosted: Sun Jan 13, 2013 12:50 pm
Milatsmadmini
For what its worth I love my 4 blade fan, pushes a shiteload of air, noisy? Yep, can I hear it over the sound of a fat Weber and exhaust? Nope :)
As others said sort the rest of ur cooling first, flush and reverse flush everything, use a good, real coolant (ones that you have to make up are good, little bottle of tectaloy gold is great) well sorted radiator, good working thermostat should make it cooler for ya!
