It is currently Tue Jul 22, 2025 12:12 am
 Post subject: Fan on backwards
PostPosted: Sat Jan 12, 2013 3:11 pm
ok so i have found my weakness ..
i can't for the life of me tell if my fan is on the wright way ..
i thought it was fine buyt now after looking at the Cooper on the shannons auction im all confused.. would this explain why the Fan is so noisy ?
Beanie
I am the son of the STIG
HOTBRICKS
http://hotbricks.org.au/
'65 NCF MINI.....
PostPosted: Sat Jan 12, 2013 3:14 pm
The reason its noisy is because its a 4 blade fan.
PostPosted: Sat Jan 12, 2013 4:07 pm
There's a nice explanation of the noise levels for the various types of fans here - http://www.minisport.com.au/category3_2.htm
PostPosted: Sat Jan 12, 2013 6:12 pm
I take exception to the 1st line in that Minisport ad, sure they were designed for Australian conditions:
In 1965 we got a new improved radiator with 16 gills (fins) per inch.
Was still a 3 core but cooled much better than the previous ones.
As for fans, I believe the original 16 blade metal fan on our cars was an Australian design, then adopted by the Poms.
IMO it's still the best/quietest for a road car. :wink:
Cooper S overheating in traffic? that's a /flame subject for another thread.. :lol:
PostPosted: Sat Jan 12, 2013 7:45 pm
I think the four blade fans will only go on one way?
And yes they are very noisy.
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Sat Jan 12, 2013 8:51 pm
Yes, the 4 blade can only go in one way.
PostPosted: Sun Jan 13, 2013 10:30 am
Ditch that noisy thing, sounds terrible!
:shock:
PostPosted: Sun Jan 13, 2013 12:13 pm
Cheers Guys i was pretty sure that it was correct...
but i thought i best just to check ..
would a six blade fan be better for air movement ?
just trying to chase a heating issue,
Beanie
HOTBRICKS
'65 NCF MINI.....
PostPosted: Sun Jan 13, 2013 12:22 pm
I would look at whatever is causing the heating issue. The fan is not causing it to overheat.
PostPosted: Sun Jan 13, 2013 12:50 pm
Milatsmadmini
For what its worth I love my 4 blade fan, pushes a shiteload of air, noisy? Yep, can I hear it over the sound of a fat Weber and exhaust? Nope :)
As others said sort the rest of ur cooling first, flush and reverse flush everything, use a good, real coolant (ones that you have to make up are good, little bottle of tectaloy gold is great) well sorted radiator, good working thermostat should make it cooler for ya!
Users browsing this forum: Majestic-12 [Bot] and 68 guests
