It is currently Thu Aug 14, 2025 9:57 pm
PostPosted: Sun Feb 24, 2013 10:46 am
hi everyone
my mini is running excellent except for the wiper arm keeps coming off when its raining . Is this and issue with spring tension or will it be to much wear in the arm. the arm was on the drivers side, and fell off so i swaped it to the passenger side and it still fell off. any advice or tips would be appreciated.
dan
PostPosted: Sun Feb 24, 2013 10:59 am
Sounds like the spline is worn out , take the arm off and see how much spline is left inside , and also check the spline on the scuttle , where it attaches .
PostPosted: Sun Feb 24, 2013 11:02 am
Looking inside the cup on the arm, what dose the retainer spring/clip look like. If it's too worn or damaged that could be your problem. Also what are the splines like?
Maybe remove the good arm and compare the two to see if one is worn, damaged or missing any parts.
PostPosted: Sun Feb 24, 2013 11:58 am
thanks for the replys i will go nave a look.
PostPosted: Sun Feb 24, 2013 12:49 pm
However, that rain HAS BEEN a little bit heavy..
PostPosted: Sun Feb 24, 2013 4:05 pm
i havnt driven it since january but thought i would have a look before i drive it in march, this heavy rain just reminded me :D
Users browsing this forum: No registered users and 255 guests
