It is currently Wed Aug 13, 2025 6:09 pm
PostPosted: Wed Aug 13, 2014 10:01 am
So a few weeks ago I fitted my kit into the dizzy (Dad was a bit peeved that I pulled the whole dizzy out 'changed everything about' then put it back in and started "perfectly" :twisted:, still need to re-time her but she runs well enough) I didn't go about fitting in the black box as of yet thought I would get to it in future. But what sort of curves are you guys running? what is the best way to work out what curve I should be running? or should this be all set up on the rr? most probably with the help of mini classic..
Nick
PostPosted: Wed Aug 13, 2014 11:05 am
For a start you can plot your curve against the published curves in the workshop manual, and then you can go from there.
Whether you use trial and error or a dyno you can choose, but the standard curve is your jump off point.
PostPosted: Wed Aug 13, 2014 12:41 pm
In my case, I used my dialback timing light to work out the curve from the Pulsar dizzy I had in, then put that map into the black box.
I've massaged the curve a bit since, but it was close to being correct.
My curves are shown in the Stealth box thread.
[edit] Here's my current map, note I add 10deg all to these points (by setting dizzy @ 10degBTDC, not at TDC) because of my race head's bathtubbed chamber shape.
Users browsing this forum: No registered users and 274 guests
