It is currently Tue Jul 22, 2025 3:08 pm
PostPosted: Tue Jun 04, 2013 2:59 pm
Are there specific areas that under body sound deadener was applied or excluded from?
PostPosted: Tue Jun 04, 2013 3:02 pm
It was pretty much applied stem to stern, including the wheel arches.
But not that vertical face of the sills (below the chrome strip).
Was done before subframes were fitted.
PostPosted: Tue Jun 04, 2013 3:54 pm
cheers,
I assume the tunnel was also done then.
How far up in the fire wall did it go, under the steering rack mount or under the bulk head
PostPosted: Tue Jun 04, 2013 4:49 pm
Up to the underside of bulkhead I think.
PostPosted: Tue Jun 04, 2013 6:22 pm
Was it painted body colour or natural grey/black?
PostPosted: Tue Jun 04, 2013 6:28 pm
It was body coloured, there was a certain brand used, and gives the smoothish leathery finish, not the crap that you see applied to that looks a bit like stucco.
PostPosted: Tue Jun 04, 2013 7:57 pm
This is good stuff, if it holds rusty UK mini's together it must be. I used it on mine, sticks like sh*t and tough. Plus you can paint straight over it, don't overdo the paint but, otherwise the paint will chip off tex coat.
http://www.hex.co.uk/tds/upol/gravitex.pdf
