If the rollers do not cover the valve stems, the rockers need shimming or mods to move them. This `should' only be needed on exhausts, because the exhaust valve positions were moved on 1275 heads compared to smallbore heads (to fit the bigger valves in).
Some makers supply a different set for smallbores only...
I have also noticed that rollers can beat up the tops of the valves compared to regular rockers. Danny's inlet valves (almost new) were particularly bad, they had a radius worn into the end. But the rollers on the 1.3 rockers were still fine.
DrMini- 1970 wasaMatic 1360, Mk1S crank, 86.6HP (ATW) =~125 @ crank, 45 Dellorto (38 chokes), RE282 sprint cam, 1.5 rockers, 11.0:1 C/R.
