It is currently Tue Jun 24, 2025 1:31 pm
PostPosted: Fri Jul 05, 2013 6:23 pm
Milatsmadmini
Has anyone done it?
http://www.minisport.com.au/prod1916.htm
Is that kit needed?
I have a set of 1.3 rollertip rockers from Mini****t and only realised as i was setting clearances how "out" a few of the tips are...
Just the tips... :lol:
PostPosted: Fri Jul 05, 2013 7:14 pm
If the rollers do not cover the valve stems, the rockers need shimming or mods to move them. This `should' only be needed on exhausts, because the exhaust valve positions were moved on 1275 heads compared to smallbore heads (to fit the bigger valves in).
Some makers supply a different set for smallbores only...
I have also noticed that rollers can beat up the tops of the valves compared to regular rockers. Danny's inlet valves (almost new) were particularly bad, they had a radius worn into the end. But the rollers on the 1.3 rockers were still fine.
PostPosted: Fri Jul 05, 2013 11:02 pm
Chong bolted His Minisport 1.3s straight onto mine?
1975 Clubman
1152cc, 40dcoe weber, RE83 cam, GRed head.
PostPosted: Fri Jul 05, 2013 11:11 pm
Pull the rocker cover and look in from the front. The rollers don't have to be dead central on the valve stem but they should cover it.
