It is currently Tue Aug 19, 2025 12:01 am
 Post subject: Gearbox build?
PostPosted: Sat Jul 06, 2013 10:40 pm
I have a four syncro remote gearbox housing, and gear set. It has a couple of damaged gears (snapped off teeth) on the laygear and on the 2nd or 3rd gear. Anyway can I fit a complete gear set from a four syncro rod change gearbox into the remote housing?
Are parts (gears) interchangeable?
PostPosted: Sat Jul 06, 2013 10:45 pm
All will fit, except reverse. It has the same tooth count but the fork slot is in a different place, so use your old one.
PostPosted: Sat Jul 06, 2013 11:35 pm
That's good news.
Where from and what brands are best for box bearings and thrust washers etc?
PostPosted: Sun Jul 07, 2013 8:44 am
Kennomini wrote:
That's good news.
If you want all the gearbox bearings Karcraft does a kit, with or without the 2 diff ones. It saves you a few bucks.
Likewise they have the copper and (correct thickness) fibre washers for the diff.
PostPosted: Sun Jul 07, 2013 8:44 pm
I'm fitting a Quafie 36K ATB diff (pot joints), what diff bushes etc do I need?
PostPosted: Sun Jul 07, 2013 8:48 pm
None internally.
But the 2 side cover bushes are probably worn as usual, I would fit new ones.
Note these need machining to size after press fitting- boring them in a lathe is the best method, IMO.
Users browsing this forum: No registered users and 339 guests
