It is currently Sat Aug 23, 2025 10:58 am
 Post subject: Fuel Pump Question
PostPosted: Wed Jul 24, 2013 7:16 am
Hey guys
Need to replace my fuel pump - twin HS4's please a reasonably hot engine and I may head to a weber 45 in the future.
I am looking at high flow pumps but didn't know if it would cause issues with the HS4's ??
What do you guys suggest as a fuel pump.
PostPosted: Wed Jul 24, 2013 7:52 am
If you are after electric. facet cube is fine. make sure whichever has a prefilter inline.
The pressure is 3-3.5 tops -whether SU or Weber. I don't run a weber but run twin HS4s and facet + standard quarter inch fuel hose delivers more than enough.
PostPosted: Wed Jul 24, 2013 8:50 am
i carry facet electric fuel pumps in stock, no problemo
Matt
0407 135 656
PostPosted: Fri Jul 26, 2013 7:12 am
Thanks guys
PostPosted: Fri Jul 26, 2013 3:22 pm
What happens if your fuel pressure is too high? I think my electric fuel pump from the previous owner is doing something like low 5s. The float and everything seems to be working alright when I switch it off and pull the assembly apart.
PostPosted: Fri Jul 26, 2013 3:33 pm
If it doesn't flood, it is fine... :wink:
Some folks add a regulator to a higher pressure pump but some (Pur******) regs are unreliable and poorly calibrated.
I have run the square Facet/Purolator/TRW/insert name here/ pumps on both SUs and Dellortos with no regulator, and no problems.
Mount them on rubber and you can't hear them with the engine running.
Users browsing this forum: No registered users and 270 guests
