It is currently Tue Aug 05, 2025 11:51 am
 Post subject: Slave cylinder line
PostPosted: Fri Aug 02, 2013 8:04 pm
Has anybody run a direct flexible line from the master cylinder to the slave instead of the 2 piece system that is standard .
PostPosted: Fri Aug 02, 2013 8:06 pm
yes
PostPosted: Fri Aug 02, 2013 8:21 pm
yes mine has a flexible line direct from the master to slave cylinder.. works fine...
PostPosted: Fri Aug 02, 2013 8:37 pm
Any disadvantages? I am using a falcon slave cylinder.
PostPosted: Fri Aug 02, 2013 9:09 pm
not that i am aware off, works well for me, any reason your using a ford slave cylinder???
PostPosted: Sat Aug 03, 2013 5:11 pm
Well I was at a mates place to change the clutch arm etc as I thought that was the problem but it turned out to be the slave cylinder , I had taken a spare everything with me but the slave cylinder was new about 20 yrs ago and so was it was stuck , my mate had a falcon one there as a spare so we fitted that and all was well with the world. Is the flexible hose off something in particular or did you have it made ?
PostPosted: Sat Aug 03, 2013 6:36 pm
it came with the last mini i bought so i couldnt tell you, i think minispares sell them for a late rover version?? not too sure tho, it has banjo fittings on bothe ends
PostPosted: Sun Aug 04, 2013 9:22 am
Ok I will have a look, Thanks
Users browsing this forum: Bing [Bot] and 86 guests
