It is currently Sat Aug 02, 2025 8:18 pm
PostPosted: Thu Sep 19, 2013 7:22 pm
Die Die Die!!
is it better to grease wheel bearings when installing or just use the grease thats been packed in from factory?
should you remove the old grease ?
should you pack more on top ?
which grease is best?
i know theres plenty of Guru's who can shed some light on the matter
Nick
PostPosted: Thu Sep 19, 2013 7:28 pm
New tapered roller wheel bearings are not packed with grease as supplied.
I leave the old grease in, unless I'm taking it all apart.
If I'm taking it all apart I always fit new bearings + seals, and pack them with Castrol HTB grease(usually).
However, when I did the Timkens in my current Mini 10 years ago I packed them with ordinary Mobil 2000 EP2 grease, I have done probably 75,000 miles since and it's still in there. Ain't broke yet...
PostPosted: Thu Sep 19, 2013 7:34 pm
Die Die Die!!
Catrol HTB it is then,
also my new hubs seems to have a little bit of surface rust from sitting (they are brand new), is it ok to give it the once over with some 1200 wet/dry to remove ?
PostPosted: Thu Sep 19, 2013 8:03 pm
Sure.
PostPosted: Thu Sep 19, 2013 9:43 pm
This should be a how to do/sticky, a lot of people do not know how to pack wheel bearings.
its messy, but if you do it right you will not have any probs!
Why is it the things that make me tick, are also the things that make me go boom?
Users browsing this forum: Bing [Bot], s-c1293 and 102 guests
