It is currently Fri Jul 18, 2025 9:02 pm
PostPosted: Tue Oct 15, 2013 7:10 pm
so literally a mile or so from home, but luckily on my street, the dreaded lose all power and come to a stop (3 mins earlier I was in the middle lane on the F6 doing 90ks!)
I took a wild guess to what it was as it had done something similar before years ago and yep, the low tension wire from the coil inside the dizzy had come away from the small nut on the points.
I go to try and unscrew it to get it back on and the thread inside the screw snaps off with the nut still attached, and then the plastic plug behind that splits in two as well!!
My question is, do I get a whole new distributor or is this part replaceable? and or worth replacing??
the nut highlighted here is what came off
Luckily the NRMA man was there in 10 minutes, attached an electric ignition bypass or something and got me started to go the last bit up the hill home.
thaks in advance for any of your help once again
Steve
1968 Mini-Matic
PostPosted: Tue Oct 15, 2013 7:16 pm
Steve, it is the 21st century, put an electronic module in it. `Convertible Mini' on here sells them, so do the usual suspects.
If you can't get one for an Aussie 29D dizzy I would fit a later one (43D/45D) which don't wear themselves out as fast.
PostPosted: Tue Oct 15, 2013 7:34 pm
I was planning on doing that (one day . . ) but I guess have been kicked into it eh?
I'll get it towed to Graeme Lord's to upgrade it when he can
:lol:
1968 Mini-Matic
PostPosted: Tue Oct 15, 2013 8:14 pm
:lol:
Steve I have one of Convertible Mini's Electronic modules. I think he does a 29D Kit.
Installing is as easy as fitting new points, very simple just DIY. Then never set points gap again.
PM here.... http://www.ausmini.com/forums/memberlist.php?mode=viewprofile&u=645
PostPosted: Tue Oct 15, 2013 8:17 pm
Hi Phil
do I still need the corroded bits that fell apart but?
when it comes to electrics, I'm not the brightest spark believe me!!
1968 Mini-Matic
PostPosted: Tue Oct 15, 2013 8:39 pm
The module has 2 wires attached, both go up to the coil. I don't think you need the breaker plate to dizzy wire, and you definitely don't need the old coil to points post wire.
Looks similar to this one- http://www.flickr.com/photos/31275265@N05/10288746954/
Last edited by drmini in aust on Tue Oct 15, 2013 8:42 pm, edited 1 time in total.
PostPosted: Tue Oct 15, 2013 8:41 pm
SteveOB wrote:
Hi Phil
I'm pretty sure the part you are talking about is part of the points, which are replaceable anyway. They are normally replaced when worn anyway.
This is the points set and condenser I removed to do my replacement.
The electronic replacement will look sorting like this.
PostPosted: Tue Oct 15, 2013 8:46 pm
yep pretty much - but do I still need that nut and screw to be attached as mine snapped right off!
and can any idiot (as in THIS idiot) do this job pretty easy??
1968 Mini-Matic
PostPosted: Tue Oct 15, 2013 8:59 pm
All you need is the little screw that holds the fixed point plate on.
Yes it's idiotproof. Just do NOT leave the ignition turned on more than 30 secs or so without the motor running or you can fry the module.
If you have a radio in there don't wire it through the ignition switch unless it has an acc position.
PostPosted: Tue Oct 15, 2013 9:13 pm
No, not if it's part of the points. Normally when you replace the points and condenser everything in my first photo goes in the trash.
Steve it's easy. The points are removed by undoing the big slotted screw in your pic at the middle arrow. You would also undo the small phillips screw to remove the condenser. Just be careful not to drop the screw into the dissy.
It all just lifts out. You could then just replace with a new points set and condenser, set the gap of the points to the correct opening and you are back in business as before.
If you decide to fit the electronic kit the plate is the same shape and just bolts in the same way, theres no condenser anymore but there now two new wires that go to the coil.
There is also a circular tigger that you slip down over the shaft under the rotor button.
The only thing I'm not sure of is once you install the electonic kit do you need to get the timing rechecked ??because it could be slightly different. I'm not sure of that but someone will know.
PostPosted: Wed Oct 23, 2013 11:46 am
so with great thanks to Tony (Convertible Mini) and the new electronic dizzy fitted by Graeme Lord's automotive, I have my Mini back on the road with much improved starting and oomph!
highly recommended
:D
1968 Mini-Matic
PostPosted: Thu Oct 24, 2013 8:44 am
Yes Steve it is amazing what good performance improvements one gets by fitting a decent Electronic distributor? I am glad to have been of assistance to your problem.
"Let us remove your "SHORTS"
