It is currently Fri Jul 18, 2025 11:52 pm
 Post subject: Reversing light???
PostPosted: Mon Nov 04, 2013 7:19 pm
Hi everyone
Went for RWC today and one (!) of the points was my reversing light wasn't working
I have a 1976 leyland mini clubman (povo model) and I never knew it had a reversing light. Ok I have only owned a week but there doesn't seem to be a clear part on the rear light cluster.
Can someone enlighten me?
It wouldn't matter if it was working as the ball joints, engine mounts and rear brake cylinders all required " a little attention"
Gotta love minis eh!
Thanks guys
Rob
Black is the new Black
 Post subject: Re: Reversing light???
PostPosted: Mon Nov 04, 2013 7:23 pm
BOOM TISH!!
he's correct, both rear indicators should come on when in reverse - there's a switch on your gearstick housing, under the floor, or there should be
PostPosted: Mon Nov 04, 2013 7:26 pm
Well you learn something new everyday. Thanks mate
Just got to get indicators , working too. Think I could have dislodged an earth or something at the weekend cleaning it up. Doh!
Rob
PostPosted: Mon Nov 04, 2013 9:53 pm
Is this the same On the 71 Simon?
If so mine doesn't work
PostPosted: Mon Nov 04, 2013 10:58 pm
The ADR for reversing light came in about 71/72 (if I remember right) ... checked.. was ADR1 - 1 Jan 72 http://www.infrastructure.gov.au/roads/motor/design/pdf/01.pdf
So a 71 might not have them...
If your car still has original type gearbox (remote change) the switch is actually on the front of the gearbox...
If NOT fitted will have large hex plug as per this photo :
If it has reverse lights - then will have a switch fitted there and some green wires ..
like this : http://www.classicmotoring.net.au/cmos/index.php?main_page=product_info&cPath=6_146&products_id=1280&zenid=f140ddd44cabc7206c2def3b60ebe388
and, of course - can check number of wires going to rear indicator if only 1 - no reverse, if 2 then has reverse...
(The 76 model will have the rod change gearbox and switch as Simon described...)
PostPosted: Tue Nov 05, 2013 7:05 am
Underground, overground, wombling free
I have a 76……… I had the same problem when I came to road worthy my car.
Lucky for me the guy that did the road worthy is a mini mechanic so he let it slip…..mumbled something about getting the right bulbs….or something. :roll: :roll:
And yes the switch on my car is in the gear leaver…….
In saying that I did rego a old four wheel drive once and had fitted after market rear lights that did not have a reversing light.
I got away with putting in a reversing buzzer …… and the guy that did the road worthy did even question it.
So that might be a easier option ………check with your road worthy guy to see if you can have a buzzer instead of a light….
Cheers Neil
I have a mini because I'm not allowed to play with small thermo nuclear weapons any more. (bloody neighbours you’d think they would be happy that they don’t have to turn a light on when they need to take a leak in the middle of the night)
PostPosted: Tue Nov 05, 2013 7:27 am
The rear indicator/rev lamp bulbs on a Clubby should be dual filament, 21/21W.
PostPosted: Wed Nov 06, 2013 2:31 pm
So to ask a dumb question. Where does the switch fit on a rod change reverse model? Is it on the gear lever
Cheers guys
Rob m
PostPosted: Wed Nov 06, 2013 5:29 pm
Got it. On floor
Thanks dudes
PostPosted: Wed Nov 06, 2013 6:37 pm
Hey guys
Just a quickie. Apart from mini spares are there any other good parts suppliers in Oz. Or do most people use mini sport UK?
Cheers again
Rob M
PostPosted: Wed Nov 06, 2013 6:46 pm
sorry to hijack but saves multiple threads, ive got a 73 van i don't have the bolt hole but i have green wires in the wiring loom in the engine bay labeled reverse switch... i have no idea tbh
PostPosted: Wed Nov 06, 2013 8:05 pm
Robmitch916 wrote:
Hey guys
Cheers again
Rob M
Hi Rob Karcraft are very good and fast shipping , just send them an email and they will email you a catalog
http://www.karcraft.com.au/
Cheers Bill
PostPosted: Wed Nov 06, 2013 8:14 pm
Thanks Bill
PostPosted: Wed Nov 06, 2013 9:30 pm
Robmitch916 wrote:
Hey guys
Cheers again
Rob M
To avoid numerous posts from people all telling you about their favourite Mini parts supplier I suggest you have a look here and decide yourself based on type of vehicle, location, cost, quality of the goods, delivery urgency, etc. They all have advantages and disadvantages. The forum is impartial.
viewtopic.php?f=25&t=10543
