It is currently Sat Jul 19, 2025 2:55 am
PostPosted: Wed Nov 20, 2013 2:14 pm
While fitting the disc brake assembly to the passenger side the drive shaft came out of the diff end joint. I shoved it back in and it appeared to be all sweet apart from getting the boot clips back on. Mucking about with the rims and tyres the other day I discovered the wheel won't rotate for more than about 1/8 turn forward or backward - car is not in gear and the other side rotates OK.
What could have happened and how do I tackle it?
PostPosted: Wed Nov 20, 2013 2:18 pm
Has a circlip possibly gotten into a ballrace and locked it maybe?
PostPosted: Wed Nov 20, 2013 3:12 pm
Does it turn with the wheel off?
PostPosted: Wed Nov 20, 2013 3:13 pm
No
PostPosted: Wed Nov 20, 2013 3:26 pm
Take the boot off the pot joint that side and verify all the balls are back in the slots properly.
PostPosted: Wed Nov 20, 2013 3:58 pm
Sounds like a plan - thanks
PostPosted: Wed Nov 20, 2013 5:36 pm
I got grease coming out of mine there less then 6 months old
