It is currently Tue Jul 22, 2025 8:41 pm
 Post subject: Noisy CV - loose nut
PostPosted: Wed Jan 01, 2014 8:20 pm
Hello.
I've been embarrassed and annoyed driving around lately with a noisy LH driveshaft.
New year's day brought the opportunity to inspect. To my surprise, it seems that the castle nut backed itself off from the 150lb/ft until it contacted the split pin. So, not a long way at all, but enough to cause a heck of a lot of noise!
This time around, I went to the 150lb/ft, then tighter until the next split pin hole appeared.
Has anyone else had similar trouble? ie 150lb/ft not enough or nut undoes until the split pin stops it?
The whole hub assembly is brand new - ie only 12 months and 1700 miles on them.
Matt
'68 Deluxe w/Metro engine
 Post subject: Re: Noisy CV - loose nut
PostPosted: Thu Jan 02, 2014 7:51 am
It happens,
mostly they simply "settle in".
the flange , the bearings, the nut & the split-tapered collar all wear-in over a short time
& will need a little "re-tighten"
we "re-tighten" everyone-one we do after a few days of running around
edit-->
just a little trick that often helps stop the nut coming loose-->
when fitting it all up, we fit the tapered collar on backwards first,,,
tighten the whole lot up that way so the tapered collar doesn`t "Pinch-up" on the cv shaft before it pulls the bearings up tight... then undo the nut, swap the collar around the right way & re-tighten & fit the split pin.
PostPosted: Thu Jan 02, 2014 7:57 am
Matt
I now follow the CV nut tightening advice you gave a couple of years ago....tighten everything up using a flat washer instead of the tapered one, then refit tapered washer and retorque. Works for me and a great hint, as over the years i have had CV nuts loosening off.
PostPosted: Thu Jan 02, 2014 8:00 am
Thanks guys. Good to know!
Users browsing this forum: s-c1293 and 83 guests
