It is currently Mon Jul 28, 2025 5:52 am
 Post subject: Squeaky clutch pedal
PostPosted: Fri Jan 17, 2014 10:26 pm
What should I put on it to get rid of the squeak?
Ryan Filippi
Minis In The Gong
[email protected]
www.minisinthegong.com.au
 Post subject: Re: Squeaky clutch pedal
PostPosted: Sun Jan 19, 2014 10:34 am
Probable some spray grease would be easiest.
PostPosted: Sun Jan 19, 2014 11:52 am
Spray grease, or to a letter extent, wd40 may work for a while, but the longest running solution is to pull the pedal box out and grease it when re-assembling it. The squeak will be the bush on the shaft which could be tricky to lubricate with it all in the car.
