It is currently Sat Jul 19, 2025 2:28 pm
 Post subject: Uni joints
PostPosted: Sun Apr 20, 2014 9:16 pm
I'm after some advice about uni's what is the better type rubber or the plastic?
And can they be simply just swapped out the car is a standard 998 deluxe with the rubber ones, but one is worn so was going to put the plastic ones in
thanks Mitch
 Post subject: Re: Uni joints
PostPosted: Sun Apr 20, 2014 9:20 pm
The pastic with bearings ones are much better than the rubber ones..... especially if your car has oil leaks.
On my old clubby, I put some new rubber ones in without fixing all my leaks....... they only lasted a couple of months.
Haha
Dusk Blue
1964 850
PostPosted: Sun Apr 20, 2014 9:25 pm
Yes this car has some bad oil leaks fixing them while its apart then put the plastic ones in
thanks for that
PostPosted: Sun Apr 20, 2014 9:31 pm
Just check to see if the bearings in the metal/ plastic ones are moving freely and have enough grease. Its hard to tell from your pic if they are in good condition.
Dusk Blue
1964 850
PostPosted: Sun Apr 20, 2014 10:09 pm
You can replace the U/J once you pull the cups off.
It's a TriumphTR6 U/J, common p/no is GUJ102. Karcraft # RTC3458/1
Current Hardy Spicer number is K5-L4R
PostPosted: Mon Apr 21, 2014 12:20 pm
I've just swapped over to a set of the needle bearing ones. The part number above (GUJ102) from Karcraft are $17 each for good brand ones (GKN). Mine had slightly different u-bolts for each set though, one were a bit thicker and the other a bit thinner, and fit the plastic cups better.
New inners on the left, old ones in the middle and rubber ones on the right:
