It is currently Fri Jul 18, 2025 3:25 pm
PostPosted: Mon Jun 02, 2014 5:08 pm
hi am after some one who can weld a piece onto one of my mags. can anyone recommend anyone . I was going to rub them back and paint the others but if its not to cheap might get a company to repaint them as weld as the welding . I have found a company called alliance wheel repairs so ill call them tomorrow. what are your thoughts and any ideas on cost. the welding needed is on the lip of rim about 70mm by 10mm approx.
PostPosted: Mon Jun 02, 2014 6:19 pm
Alliance are about the only ones in Perth that I know of. Plasti dip is always an option for colouring rims then just peel it off shen you want to change it. I stock a few colours of plasti dip at For Parts in Landsdale.
1965 Riley Elf
1974 Ex Army Moke
1997 Rover Cooper
2002 JCW Cooper
2003 JCW Cooper S
PostPosted: Mon Jun 02, 2014 6:38 pm
I'd assume anyone who was a good tig welded could do the welding then it's just a matter of shaping it correctly...probably easier to get a pro to do it :roll: .
PostPosted: Mon Jun 02, 2014 7:44 pm
Used to be Leo Gommer engineering over near Jandikot. Not sure if he's still there though.
He would repair wheels like I would have hot dinners. He was very good with a TIG,
PostPosted: Mon Jun 02, 2014 8:36 pm
ill give the alliance guys a call I've found someone in canning vale too so ill compare. also I found leos details; they are as follows I anyone else is after him ,
Leo Gommers Engineering 2 Gibb St, Cannington, WA 6107 p: 08 94515238
plasti dip sounds different does it still give a smooth finish as if it was painted. never used the stuff. what does it cost. was just going to spray wheels silver most probably
PostPosted: Mon Jun 02, 2014 8:47 pm
Leo is where a large number of auto repair shops sent their wheels to be repaired. So good I wondered at the time how many insurers and customers thought they were getting new wheels...
He got me out of a nasty fix with a bent pair of wheels 4041 klms from home.
PostPosted: Mon Jun 02, 2014 8:55 pm
yeah I might just go with him tomorrow if hes that good id rather use a recommend chap. thanks for your help
PostPosted: Mon Jun 02, 2014 10:15 pm
The plasti dip leaves a smooth finish on them like paint. $30 a can, 2 or 3 cans would easily do a set of mini wheels.
1965 Riley Elf
1974 Ex Army Moke
1997 Rover Cooper
2002 JCW Cooper
2003 JCW Cooper S
