Rover Cooper |
Joined: Sat Feb 03, 2007 9:15 am Posts: 2401 Location: Werribee Vic. RETIRED - VMCI 3225 ,
measure from the centre of the bonnet to the outside edge of the car and then add what you think is enough clearance for the car to be off the floor when it is sitting vertical, or work out an acceptable working height so you can stand up straight when working on the car, I have one which is identical to the car stands with a centre support with a series of holes drilled which I can push a pin into and this makes it adjustable and much more flexable, works for me.
