It is currently Sun Aug 03, 2025 6:57 pm
PostPosted: Wed Jul 02, 2014 4:40 pm
Was installing smiths rev gauge in my leyland 78 and the car was cutting out. Eventually didn't start . Finally worked out the module in dizzy had crap itself . Why???? Your help is much appreciated
PostPosted: Wed Jul 02, 2014 4:53 pm
Was it the inductive loop type? Was there any connections in the circuit to the rev counter?
I have been running an A Smiths RVI revcounter for five years on the one module, and they don't consume any significant power in doing so. They technically should be fine.
Did you remove the tacho from the circuit, and rewire the tacho directly back to the coil with a different short wire?
As a rule of thumb, heat kills the modules (>180 degrees at the module itself), also reverse polarity, and over voltage.
PostPosted: Wed Jul 02, 2014 5:17 pm
Image had different wire to coil running through firewall when I tested the power to the fuse box it was trying to cut out car
PostPosted: Wed Jul 02, 2014 5:20 pm
Ok, so its not inductive.
That black wire under the 4&6 Cyl termination, what is that about, and where is the 8 cyl termination going to?
Do I assume the blue comes from the coil?
PostPosted: Wed Jul 02, 2014 5:56 pm
Disconnected the brown .black I assumed was earth ,only black / red white / green/ red was coming out of bottom. I will open gauge and let u know. Thx Mick
PostPosted: Wed Jul 02, 2014 6:26 pm
So the module works fine, until you try to connect the tacho to +ve 12 volts. Then you can't really blame the module.
I'm trying to find an image of the wiring for one of these tachs, but am not having any luck. They're the plastic pod tachos aren't they? I don't think that's a very correct setup.
PostPosted: Wed Jul 02, 2014 7:51 pm
Some of these aftermarket electronic modules can die from heat if you leave the ignition on for a few minutes with the engine stopped.
Pertronix 1 was known for this problem, and I blew a blue UK one once the same way.
ps. If anybody runs one of these modules on a roundnose Mini I would not wire the radio thru the ignition switch, unless it has an accessory position.
PostPosted: Thu Jul 03, 2014 6:57 am
Yea it is the plastic pod ones.& I did leave ignition on for a bit!
PostPosted: Thu Jul 03, 2014 8:19 am
Is it wise to join the wire from coil with a switch for a kill switch?
PostPosted: Thu Jul 03, 2014 8:23 am
It doesn't hurt. And it's a simple theft deterrent. :wink:
PostPosted: Fri Jul 04, 2014 6:33 am
I have Mini Ignition switches with an accessory position which will prevent these problems. They look the same as the original. They have accessory/Off/Ignition/Start. PM me if any one wants one. They are quite inexpensive and worth fitting.
Sometimes I read about problems have with their Mini related to Ignition circuit. Most times it is an overloaded Ignition switch. Remember the contacts in a 50 year old switch will not be what they should be after having been turned on and off carrying God knows what current for so many years.
"Let us remove your "SHORTS"
Last edited by Convertible Mini on Sun Jul 06, 2014 2:54 pm, edited 2 times in total.
PostPosted: Sat Jul 05, 2014 5:11 pm
My rev gauge says RVI , will the problem be solved if buy a RVC gauge or can the one I have be converted to work with a elec dizzy? Got kill switch to work but tacho still problem.
