It is currently Tue Jul 22, 2025 2:01 am
 Post subject: su piston and needles
PostPosted: Fri Jul 25, 2014 8:19 pm
Can a run a fixed piston and needle in a su that had a biased piston and needle
PostPosted: Fri Jul 25, 2014 8:30 pm
I converted a pair of Twin 1.5's recently from swinging needles and waxstats.
You need to buy an adaptor bush to fix the needle. Only a couple of dollars each.
viewtopic.php?f=2&t=83695&hilit=twin+1.5
PostPosted: Fri Jul 25, 2014 9:57 pm
Cant i just drop in a fix needle piston with the fixed needle in it already
Im playing around with a hs2 1 1/4
PostPosted: Fri Jul 25, 2014 10:19 pm
Yes you can, but you should use the bell that came with that piston.
PostPosted: Fri Jul 25, 2014 10:54 pm
just make a paste with some ajax and water and hone them into each other a bit.
PostPosted: Sat Jul 26, 2014 6:15 pm
Ok thanks
PostPosted: Mon Jul 28, 2014 8:38 pm
Why would you risk messing up 2 carbs when you can get the correct needle mount for a few dollars?
Cheers, Ian
