It is currently Tue Aug 12, 2025 6:31 am
 Post subject: Female UNF brake union
PostPosted: Tue Aug 12, 2014 5:23 pm
I'm currently putting my clubman back together and am doing the brake lines, I need a couple of female unf brake unions, my old ones are useless but I can't seem to find them, my local brake shop basically told me that because they are British he doesn't know where I can get them from, it's an Aussie clubman not a British one.
They are the unions that connect the rear brakes to the hose on the trailing arms, URL below should hopefully link to a uk website that sells them, but surely there most be someone in Oz selling them.
http://minispares.com/product/Classic/Brakes/Hoses/TN606031.aspx?0403&ReturnUrl=/search/classic/Female%20unf%20brake.aspx|Back%20to%20search
PostPosted: Tue Aug 12, 2014 5:35 pm
They should be pretty easy to snare off an old subframe, any will do.
I've got a couple here if you run into trouble. I would need to mail them down however from NSW.
PostPosted: Tue Aug 12, 2014 5:59 pm
Your local brake place sounds a bit slack. The local brake shop up here has or gets them
Brake Pipe Nut 3/16" x 3/8" UNF (Female) is what you need. If the brake shop is still no good, maybe just try the local parts shops, they probably don't have them but maybe can get them for you. Or the internet
PostPosted: Tue Aug 12, 2014 8:03 pm
Or call Karcraft.
PostPosted: Wed Aug 13, 2014 4:01 pm
I haven't bought from them (yet), but I found the following place sells brake line parts.
http://brakehose.com.au/shop.php
Scroll down nearly half way to the "Tube Nuts" section and have a look. I think it is the BQ55. It's also available in Stainless Steel and called SS55.
'64 Mini 850 in need of a total rebuild (and a 1275 A+, and disks, and a whole lot more)
PostPosted: Wed Aug 13, 2014 5:14 pm
I've got a couple in Bentleigh that you are welcome to.
Correction: They were binned with the rear subframe offcuts last week. I thought I'd pulled all the hardware. Sorry. :(
1998 Rover Mk VII
2001 Honda CBR 929RR (street)
2014 BMW S1000RR (track)
PostPosted: Wed Aug 13, 2014 9:10 pm
Thank you all for your help.
I ended up emailing Karcraft who don't actually sell them, but they did point me in the direction of http://www.brakehose.com.au/shop.php who do sell them :D
PostPosted: Wed Aug 13, 2014 9:21 pm
The Mini King
Mini kingdom online have them in stock if you are stuck,
PM sent
Users browsing this forum: No registered users and 297 guests
