In my case, I used my dialback timing light to work out the curve from the Pulsar dizzy I had in, then put that map into the black box.
I've massaged the curve a bit since, but it was close to being correct.
My curves are shown in the Stealth box thread.
[edit] Here's my current map, note I add 10deg all to these points (by setting dizzy @ 10degBTDC, not at TDC) because of my race head's bathtubbed chamber shape.
