It is currently Tue Aug 05, 2025 12:36 pm
 Post subject: Clubman floor pans
PostPosted: Sat Aug 16, 2014 2:22 pm
I'm trudging away at pulling out all of the bitumous matting that the previous owner of my '74 clubman had lovingly applied. I knew I'd be in for some unpleasant revelations. As well as having some rust around where the driver's heel would sit, the floor has taken some hits in other places and is deformed enough that I'd rather change it out and know that it's good.
I have an inkling that the Aus produced floors differ from the UK ones, is that correct? If so, what are my alternatives for fitting new metal? I'm not doing a resto, it doesn't need to be true to original, it needs to work, everything needs to fit, and it has to be safe. What would you do?
 Post subject: Re: Clubman floor pans
PostPosted: Sat Aug 16, 2014 2:41 pm
Minisport sa have the aus floor pressings. A really good fit but needs some time and effort do fit right.
Minis..
1976 van daily drive
1975 van
1968 deluxe in the shed
1967 deluxe high strung 1310
1959 austin healey sprite
PostPosted: Sat Aug 16, 2014 5:08 pm
In a similar vein, what do you use to replace a Van floor? Mine are made out of stoneguard with chequer plate riveted over them, so I'm assuming they're not in great condition.
PostPosted: Sat Aug 16, 2014 5:27 pm
I would buy replacement pans from karcraft in Sydney if you want to save a few bucks.
PostPosted: Sat Aug 16, 2014 6:32 pm
You can buy full lengh floor pans for the van but im pretty sure they are uk pressings.
Minis..
1975 van
Users browsing this forum: Bing [Bot] and 101 guests
