It is currently Tue Jul 29, 2025 6:14 pm
 Post subject: What is this!
PostPosted: Sun Aug 17, 2014 1:49 pm
Ok doing an oil change and found this stuck to the magnet on drain plug:
Bit worried now as the engine and gearbox has not long had a rebuild and to me looks like something has broke.
Still runs great however.
 Post subject: Re: What is this!
PostPosted: Sun Aug 17, 2014 1:51 pm
Its a bit fuzzy. Is that a piece of an allen key?
PostPosted: Sun Aug 17, 2014 2:15 pm
Bent roller from the gear box? Possibly something left behind during the rebuild
Minis..
1976 van daily drive
1975 van
1968 deluxe in the shed
1967 deluxe high strung 1310
1959 austin healey sprite
PostPosted: Sun Aug 17, 2014 2:23 pm
Just rebuilt clutch master cylinder as was backing off on its own, had a couple instance where i had to use a bit of force (not much) to get it into neutral (clutch was starting to engage while clutch pedal was fully in) so perhaps is something from the gearbox.
Better pic:
PostPosted: Sun Aug 17, 2014 2:35 pm
Better out than in!
PostPosted: Sun Aug 17, 2014 2:50 pm
Whatever it is it isnt meant to be that shape.
Definately better out.
Minis..
1975 van
PostPosted: Sun Aug 17, 2014 2:53 pm
Should i be concerned?
PostPosted: Sun Aug 17, 2014 2:55 pm
Relieved it's out! Hopefully it stuck to magnetic plug early and hasn't done any damage!
PostPosted: Sun Aug 17, 2014 3:03 pm
The drive tang on a helicoil?
It's easy once you know how.
PostPosted: Sun Aug 17, 2014 3:30 pm
It's a 5c coin. Oh, wait...
PostPosted: Sun Aug 17, 2014 3:36 pm
https://www.google.com.au/search?q=heli ... B345%3B230
Yes does look like one.
PostPosted: Sun Aug 17, 2014 4:03 pm
Diesel 27 wins the prize...a good get that. Very impressed.
PostPosted: Sun Aug 17, 2014 4:07 pm
Thats a big recoil if its the size of a 5c coin....must be the sump plug.
PostPosted: Sun Aug 17, 2014 4:34 pm
I had a gearbox here recently with a helicoiled sump plug hole, they had left the tang on but bent it outwards, hoping this would prevent the helicoil screwing out.
It looked just like this one does.
PostPosted: Sun Aug 17, 2014 5:32 pm
When the sump plug does leak (and it will because i guarantee that the helicoil is not square to the mating face and a copper washer won' be able to seal), get one of the good drmini in aust steel replacement inserts and forever have a leak free sump plug!
As far as being concerned about the internals, it is out now and unlikely to cause any more damage. It is not like it is one part of a disintegrating bearing that will ruin the rest of the engine. I doubt there were many threads that needed a helicoil, sump plug is most common, so unlikely to be more tangs floating around inside.
michael
