It is currently Tue Jul 22, 2025 1:43 am
PostPosted: Tue Oct 07, 2014 5:26 am
Anyone know for sure what the torque should be for shanked wheels nuts and flat washers? Running Revolutions and just not sure if the normal torque is dictated by the wheel stud size or the tapered style nut. Cheers
http://www.mini-hb.co.nz
PostPosted: Tue Oct 07, 2014 9:19 am
I run rose pedal rims on my race mini and set the straight shank wheel nuts at 50 ibf ft, never had any issues.
Cheers Mal
PostPosted: Tue Oct 07, 2014 9:56 am
Same, and I run 13x7" Revolution RFX.
The only time they ever came loose was before I started using a torque wrench.
PostPosted: Tue Oct 07, 2014 12:18 pm
Thanks for that. Figured it was more than normal, but don't want to go breaking studs.
PostPosted: Wed Oct 08, 2014 8:10 pm
i run them all at 42Lbs
PostPosted: Thu Oct 09, 2014 2:18 pm
It is the size of the wheel stud - 3/8" UNF - that dictates the torque spec not the wheel nut sleeved or tapered.
40-42 ft/lbs is MAX, depending on lube.
I once had to tell a Mini Meet crew that they had to replace all 8 wheel studs on a Cooper S after they broke a second wheel stud...before they could take part in the standing start fast lap competition at Blackhawk Farms in Wisconsin.
Over tightening the wheel nuts will cause the stud to fail. If you think 50 ft.lbs. is OK be prepared for breakage.
Think about it - 3/8" coarse head studs go in the block hand tight, 3/8" UNF head stud nuts are + 40 ft. lbs. Why would the same bolt be different on the wheel??
They aren't different...torque is dependent on size, threads, material.
I once visited a friend's garage as he broke a double-nutted 3/8" head stud as he was cranking it into the block...fortunately the coarse threads proved no problem in extracting the bolt broken off at the block face.
PostPosted: Thu Oct 09, 2014 3:17 pm
Stud bolt torque is limited by coarse thread which is screwed into cast block, standard 8.8 3/8 fine thread bolt is good for 49 , refer chart, wheel studs are no different. M :-)
PostPosted: Thu Oct 09, 2014 3:26 pm
For what it's worth, the Mini factory workshop manual (TP832) specifies 42 lbs/ft for the road wheel nuts, so that's the limit I'd be using.
PostPosted: Thu Oct 09, 2014 5:01 pm
interesting, I am wondering what original factory spec is for studs, all modern studs you would assume would be grade 8.8. M :?:
Users browsing this forum: Majestic-12 [Bot] and 94 guests
