It is currently Wed Jul 30, 2025 1:49 pm
PostPosted: Thu Oct 09, 2014 9:09 pm
Heya, got a problem with my brake rotors I believe. Shudders a bit when applying the brakes. can anyone recommend a place in Melbourne to machine these? I've only put new greenstuffs on about five months ago, I won't have to replace them again will I? Also, I'd prefer to have them machined when on the car if possible as I have no way of removing them myself.
PostPosted: Thu Oct 09, 2014 9:42 pm
probably cost you more to machine them than buy a new set or rotors,we normally sell both sides for around $60
PostPosted: Fri Oct 10, 2014 2:09 pm
Ahh, just checked them out on your website, that's awesome! We're in Melbourne are you located? Can I pick them up sometime next week?
PostPosted: Fri Oct 10, 2014 5:13 pm
have you checked ball joints, caliper bolts, shaft nuts, tyre pressures and rod ends?
It's easy once you know how.
PostPosted: Fri Oct 10, 2014 5:22 pm
Unfortunately, I'm not very mechanically minded and don't have the facilities to check unfortunately. Tyre pressure fine, will to putting on new rubber in next couple weeks. Had ball joint replacement couple months ago but suspect there is still a problem there as their is sometimes a slight knocking sound sometimes on the left only when going over a speed bump or something
PostPosted: Fri Oct 10, 2014 6:08 pm
Give him a call.
viewtopic.php?f=41&t=83593
Mini Imports (open by appointment)
17 Palmerston Road East,
RINGWOOD, VIC, 3134
Mob: 0419 396 877
PostPosted: Fri Oct 10, 2014 9:35 pm
Maybe try using a wire brush to clean the hubs, where it contacts the wheel, and use emery/sand paper to clean the mating surface of the wheels.
Built up rust and dust can cause vibration, that often only occurs under braking, I've fixed two cars where cleaning both parts stopped the "brake shudder"
PostPosted: Wed Oct 15, 2014 8:22 am
Nick, I don't have much plans for Saturday other than cleaning the interior after my Tassie trip. You're welcome to head down Bentleigh way and I'd be glad to lend a hand and access to tools if you're free Sat morning. I've also got a brake shop out front the house which is open until 1pm or so, they'll machine the rotors for about $40 if it is needed.
1998 Rover Mk VII
2001 Honda CBR 929RR (street)
2014 BMW S1000RR (track)
PostPosted: Fri Oct 17, 2014 6:05 pm
Thanks for all the suggestions guys, got some rotors on order and also found the key to my wheels finally. Was left at the mechanic by mistake.
PostPosted: Fri Oct 17, 2014 6:49 pm
Hey Brian is that $40 for a pair or each ??
64' 850 1275cc
PostPosted: Sat Oct 18, 2014 8:07 am
If I re correctly, it was 20 per rotor, but I've only used them for this once, and it may have been mates rates. 20 per rotor sounds like a reasonable price to me though?
1998 Rover Mk VII
PostPosted: Sun Oct 19, 2014 6:29 am
Thats what it costs down here. Sounds about right.
1963 Morris 850 Smoke Grey
1963 Morris 850 Shadow Blue
1965 Morris Mini Smooth Van
1966 Morris Mini Van
1969 Morris Mini Deluxe Resto
5/72 Clubman Gt
PostPosted: Sun Oct 19, 2014 9:32 am
Sweet I got new pads on the way I may have to pop round to urs soon if they need a shave ;-)
64' 850 1275cc
Users browsing this forum: Bing [Bot] and 80 guests
