It is currently Sat Jul 19, 2025 6:52 am
 Post subject: Accelerator pedal rubber
PostPosted: Mon Mar 02, 2015 8:24 pm
I think I fitted a Leyland clubman accelerator pedal to my car many years ago as the Morris one was just way to tinny for my size 12 foot.
This one I've got is not square but rectangular. Can you still buy pedal rubbers for this type of pedal? I've also got square clutch and brake pedals which I think the entire pedal box was also from a clubman.
PostPosted: Mon Mar 02, 2015 8:39 pm
This one seems a little bigger, but it states for early cars?
http://www.ebay.co.uk/itm/Classic-Mini- ... 1451139993
PostPosted: Mon Mar 02, 2015 8:52 pm
Hmmmm. It does say for cars up to 76. I think the clubman parts car was a 74 model. Thanks for that link.
PostPosted: Mon Mar 02, 2015 9:42 pm
The accelerator pedals in Morris Minis/Leyland Minis/Mokes/Cooper S etc were all the same, from 61 to 78 in Aus. The Minimatic had a larger rectangle shaped pedal, for reasons only BMC know, that sounds like what you have, most suppliers here in Aus dont have them, so you will have to look for NOS or a good s/h one.
The Ebay link that Mick posted has the correct early brake & clutch pads, and some generic stool rubber pad for the throttle, that were never fitted to a Mini in Aus.
A proper early throttle pedal rubber looks like this - http://www.ebay.co.uk/itm/MORRIS-MINOR- ... 43cb3bf496
A Rover Mini has a larger square throttle pedal. They never had a rubber pad fitted originally, but people often fit a early brake/clutch pad to them.
Clubman/Rover brake & clutch pads are diamond shaped and are readily available.
Here is a Clubman type and a Matic throttle pedal rubbers - http://www.ebay.co.uk/itm/austin-classi ... 2c9761ae8b
Have a Nice Day.
PostPosted: Mon Mar 02, 2015 9:51 pm
Ah ha. Yes. The Matic accelerator pedal. Right so NLA..... Bugger.
So basically.... Impossible.
PostPosted: Mon Mar 02, 2015 10:01 pm
My Matic throttle pedal has worked just fine for the last 20 years without a rubber. :)
PostPosted: Mon Mar 02, 2015 10:15 pm
I've got an alloy race pedal cover riveted to mine so if I take that off... I'll be left with two holes. Looks like it stays then...!
PostPosted: Tue Mar 03, 2015 12:37 pm
I didnt see that link the first time round.
Ive just bought it and will see how it goes. Cheers.
PostPosted: Sat Mar 07, 2015 8:56 pm
Hello Hanra,
My mini K, bought new in 1969, did not have a rubber pad on the accelerator pedal. Friends with minis at the time did not have pedal rubbers on them either. They appeared in parts shops years later.
Bill
PostPosted: Sun Mar 08, 2015 5:30 pm
The Mini King
If You like to have a larger pedal for the accelerator ,That you can fit a pedal rubber to, then I would suggest you fit NAM3108 pedal, you can then use the early Mini clutch or brake pedal Pad
PostPosted: Wed Mar 11, 2015 7:59 am
Thanks for that info John. I will look into that. I assume the throttle cable attaches in the exact same manner?
PostPosted: Wed Mar 11, 2015 10:34 am
http://minisport.com.au/mini-black-acc- ... e-only-one
....you just lost him his insurance bonus!
997
PostPosted: Wed Mar 11, 2015 11:11 am
Yeah nah. my pedal is bigger then that one. Its a matic pedal.
Users browsing this forum: Bing [Bot] and 77 guests
