It is currently Tue Aug 05, 2025 2:04 pm
 Post subject: Are these S extractors?
PostPosted: Wed Dec 31, 2014 1:06 pm
Can someone please tell me if these are S extractors? they have been messed up a bit down the bottom
are they worth anything?
Thanks Mitch
PostPosted: Wed Dec 31, 2014 1:09 pm
Yep...Cooper, but there are exhausts that flow a lot better around these days...
I wouldn't think they would be worth much...
PostPosted: Wed Dec 31, 2014 1:11 pm
Thanks for that
PostPosted: Wed Dec 31, 2014 2:17 pm
For someone building an "original" S they may be priceless... Can't be too many that haven't been ditched.
Cheers, Ian
PostPosted: Wed Dec 31, 2014 7:40 pm
Priceless...
1. of inestimable worth; beyond valuation; invaluable
2. extremely amusing or ridiculous
PostPosted: Wed Dec 31, 2014 10:45 pm
Also used on a couple of other cars with twins. Maybe MG 1100's?
They pop up, but when one wants them they're impossible to find! Ask winnabbey.
It's interesting to me that a pair of welded together steel pressings were cheaper and easier than formed tube which is the norm these days, but entirely reasonable for a company which pressed metal panels for a living.
PostPosted: Wed Dec 31, 2014 10:51 pm
Yes, MG 1100, Cooper, Cooper S, Princess, etc. Most transverse A-series with twin carbs (except for the 1300GT) got those style of extractors.
There was a slight variation in the different models though.
PostPosted: Wed Dec 31, 2014 10:52 pm
MG1100 ones were same shape but different, a bit longer? I think.
The problem with all these pressings was they were thinner than a stock 1/16" wall zorst pipe.. so did not last well.
PostPosted: Thu Jan 01, 2015 7:35 am
I still have a set tucked away somewhere as well, they came with my 70mk2 s. 8)
PostPosted: Thu Jan 01, 2015 8:45 am
1275 S ones are 1/4" longer than others because the 1275 block is 1/4" taller than other blocks. 970 & 1071 S blocks are the same height as small bore 998/1098 blocks. Not sure about 997 blocks.
RonR
68 build Mk1 Cooper S
PostPosted: Thu Jan 01, 2015 8:54 am
997 blocks are just an underbored 998/1098 block.
I took one out to 68mm bore back in 1968.
PostPosted: Thu Jan 01, 2015 9:02 am
These are sold now
PostPosted: Sun Jan 04, 2015 10:06 pm
Retro 'stractors!
PostPosted: Mon Jan 05, 2015 7:26 pm
Mick wrote:
Retro 'stractors!
So Mick should they be grey or should they be matt black from original?
Regards Pete.
PostPosted: Mon Jan 05, 2015 7:29 pm
These ones are now in winnabbeys hands. They were/are new old stock and are covered in a thick black enamel from the factory.
They weren't fitted to a car from new, so will leave the grey or black one alone as there may have been a different supply chain for the aftermarket.
