It is currently Thu Jul 17, 2025 3:16 am
PostPosted: Mon Feb 09, 2015 9:28 am
Hey all, I'm getting clunking from underneath the matic whilst driving. Noise isnt there when shifting from R/N/D but once you start going sometimes you'll hear it after shifting and sometimes when going over dips and what not. I havent yet pinpointed the exact conditions it does it in.
Whats the first to check though? 've got hydro all around. I'll try and take a video later if the video can capture the noise. its a clunk that you can kind of feel. I know car needs an alignment as I just put new wheels on but it was clunking prior to that. it seemed to be much louder when we re set the hydro suspension. I've lowered it again a bit and its a little less although definitely there.
Wife says tahts the only thing worrying her about the car lol. So would like ti know what I should be looking at to get rid of it.
PostPosted: Mon Feb 09, 2015 10:10 am
What uni joints are you running out of the diff? Rubber? Hardie Splicer? or Pot Joint?
Also, do you feel it under your feet?
If it's the rubber uni's then i would be checking the condition of them and the u - bolts!
Might also have a look at the outer CV's, is the castle nut tight on the end of the drive shaft?
Cheers Shane
PostPosted: Mon Feb 09, 2015 10:14 am
Check your engine mounts also.
1963 Morris 850 Smoke Grey
1963 Morris 850 Shadow Blue
1965 Morris Mini Smooth Van
1966 Morris Mini Van
1969 Morris Mini Deluxe Resto
5/72 Clubman Gt
PostPosted: Mon Feb 09, 2015 10:36 am
Yes, can be felt on my feet!
I forgot what unis I've got. I put it up the other day and took photos but missed the important bits LOL
that said I have not checked the engine mounts. Might be it. I imagine the 1275 will have the same mounting points. As I'm planning to put a 1275 auto in it in the coming months. I'll try and get it up later and have a better look.
whats the best way to check the mounts? I did rung up melba motors here who service minis. will get htem to have a squizz
PostPosted: Mon Feb 09, 2015 10:37 am
Thats what I took photos of atleast. but wife was pestering me to do house work so I didnt actualyl get to check things hahaha
PostPosted: Mon Feb 09, 2015 11:16 am
maybe look at the "Inner" end of your axles,,, next to the diff under the middle of the car
PostPosted: Mon Feb 09, 2015 11:31 am
yep! I took pics of the wrong end LOL i'll see if I can get it up later to have a look
PostPosted: Mon Feb 09, 2015 11:38 am
Also check the 4 subframe bolts in the floor, they have been known to come loose. Mine now have locknuts on em.
PostPosted: Mon Feb 09, 2015 11:47 am
I would check engine mounts, stabilisers, and ball joints- they can make a fair old thud when they go bad.
PostPosted: Mon Feb 09, 2015 12:36 pm
drmini whereabouts do they bolt into? I will have a look later.
PostPosted: Mon Feb 09, 2015 12:42 pm
When you look at the subframe, at the very rear of the front subframe there will be two bolts per side. Roughly where you feet would be.
5/72 Clubman Gt
PostPosted: Mon Feb 09, 2015 12:44 pm
If you gut stuck, send me a PM. More then happy to have a look for you to work out where noise is coming from. I'm in Weston Creek.
1963 Morris 850
PostPosted: Mon Feb 09, 2015 12:54 pm
Thanks mate. melba motors having a look for me tomorrow. If we cant pinpoint it I'll send you a message. but I'll get it on the hoist tonight and check the bolts anyway
PostPosted: Mon Feb 09, 2015 3:39 pm
and gear change extension mtg :idea:
PostPosted: Mon Feb 09, 2015 4:01 pm
where would I find that?? lol
