It is currently Sat Jul 19, 2025 1:41 am
PostPosted: Mon Feb 23, 2015 7:25 pm
Hey guys
I pulled down the motor on the new deluxe today.
It has an MED centre main strap.
Now the thing I am wondering is what grade bolts should becin there? MED supplied all the bits for the motor including the main strap and when I pulled it apart I noticed it had grade 3 bolts for the main strsp.
I would have expected med to supply the bolts for the strap so are these right or are the something the previous owner has grabbed from bunnings?
Rodney
Minis..
1976 van daily drive
1975 van
1968 deluxe in the shed
1967 deluxe high strung 1310
1959 austin healey sprite
PostPosted: Mon Feb 23, 2015 7:51 pm
I would expect them to be supplied, grade 8.8 at the least. I would look at replacing them.
PostPosted: Mon Feb 23, 2015 8:16 pm
I'd use some decent 10.9 cap head bolts with hardened washers.
Think I remember reading a few years ago MED had an issue with one of their suppliers sending the wrong grade bolts. Was one of the UK forums.
PostPosted: Mon Feb 23, 2015 9:37 pm
Bit of blue tack should hold it mate.
1965 Riley Elf
1974 Ex Army Moke
1997 Rover Cooper
2002 JCW Cooper
2003 JCW Cooper S
PostPosted: Mon Feb 23, 2015 9:40 pm
If there are 3 lines on the head they are grade 5.
Should be grade 8 (these have 6 lines), or better.
Grade 8.8 is used for metric bolts, is weaker than grade 8.
PostPosted: Mon Feb 23, 2015 9:47 pm
Ok cheers guys. That was my suspicion. .
Didnt want to change them if they where meant to be like that.
Off to the bolt rack at work I go..
Minis..
1975 van
PostPosted: Mon Feb 23, 2015 10:03 pm
It's your engine he's talking about mate..... :lol: :lol: :lol:
PostPosted: Mon Feb 23, 2015 10:06 pm
Five finger discount hey???
PostPosted: Mon Feb 23, 2015 10:15 pm
Yup...
Minis..
1975 van
PostPosted: Mon Feb 23, 2015 11:28 pm
Emailed MED and too their credit they emailled back in 5 mins.
Thats the bolt they use on all their street engines..
Minis..
1975 van
PostPosted: Tue Feb 24, 2015 6:51 am
It's not as though 7/16 UNF Grade 8 bolts are hard to get. Should be available from any decent fastener place.
I bought mine from Lee Bros Engineering.
They don't seem to have a website.
https://plus.google.com/102667492819785 ... l=au&hl=en
Centre straps are not really needed on a road motor, as the caps only break when you zing the motor to a zillion rpm on downshifts.
However if the cap has been thinned down to fit a strap, the cap is weakened so don't run it without one fitted.
PostPosted: Tue Feb 24, 2015 9:35 am
Yeah I think the only reason a strap was fitted was because of the supercharger. Its there now so it has to stay.
And yeah im not convinced on the grade 5 bolts do im off to the bolt shop this morning (we didnt have any in stock at work)
Minis..
1975 van
PostPosted: Tue Feb 24, 2015 11:31 am
I put arp on my centre strap and other caps, had to mod the housing to make it fit.
1965 Riley Elf
1974 Ex Army Moke
1997 Rover Cooper
2002 JCW Cooper
2003 JCW Cooper S
PostPosted: Tue Feb 24, 2015 8:39 pm
You should be able to get Cap Screws in 12.9, but they're only in metric. You'll need at least Grade 8 for Imperial, which is roughly equivalent to 10.9 Metrics.
PostPosted: Wed Feb 25, 2015 10:17 am
Hey guys,
Is the centre main strap a solid piece or is there an oil pick up hole in it? On the 1098 there is a threaded hole on the centre cap, what happens to this when you machine the centre down flat to put in a centre strap?
All the pics I've seen of the centre main straps look to be solid..
Curious..
196# Morris VAN
2013 JGC 5.7 Hemi
2012 Civic Type R
