It is currently Sun Jul 27, 2025 2:52 am
 Post subject: Mikuni HSR carby
PostPosted: Sat Mar 14, 2015 5:55 pm
I spent a little time today helping tune Gafmo's Mikuni HSR45? carby on his (was once mine)1412 stroker.
Pretty simple to tune, compared to an SU or Weber. Just an idle mixture screw, idle jet, a needle and a main jet.
I put the A/F meter on, and we went for a thrash.
Main problem was, it was going too lean at full throttle with the biggest main jet they can supply (a 220, = 2.20mm diameter). And midrange was a little rich.
I drilled a spare main jet out to 2.40mm, we dropped the needle by a notch, and VROOOOMM!! Numbers now good, it hauls ass, and sounds great too. 8)
http://www.mikunipower.com/Catalog/Miku ... g36-01.htm
Last edited by drmini in aust on Sat Mar 14, 2015 6:54 pm, edited 3 times in total.
 Post subject: Re: Mikuni HSR carby
PostPosted: Sat Mar 14, 2015 6:30 pm
genius
It's easy once you know how.
PostPosted: Sun Mar 15, 2015 8:46 am
GR should try out one of these on the dyno, see how it goes.
PostPosted: Sun Mar 15, 2015 9:56 am
Throttle response is better than an SU, sounds better too. But it doesn't sound like a pair of Harleys (as a Weber or Dellorto does). :)
PostPosted: Mon Mar 16, 2015 8:28 am
what accelerator pump adjustment does it have?
PostPosted: Mon Mar 16, 2015 9:28 am
http://www.mikuni.com/pdf/hsr_tuningmanual_021003.pdf
See p6 & p7.
PostPosted: Tue Mar 17, 2015 2:59 pm
cool - one of the main problems when using a supercharger is the lack of a "proper" accelerator pump
