It is currently Mon Jul 28, 2025 3:34 am
 Post subject: Stuck Door
PostPosted: Mon Apr 06, 2015 2:01 pm
My passenger door looks like it has dropped a bit and it won't release, it is stuck and will not open.
Are there any tricks to opening the door? It is a clubman.
 Post subject: Re: Stuck Door
PostPosted: Mon Apr 06, 2015 3:35 pm
Remove door + hinges from body?
PostPosted: Mon Apr 06, 2015 3:44 pm
It is probably the rocker arm on the linkage that has moved, it mounts on the door handle nuts.
Removing the hinges isn't going to remove a door with a burst proof lock.
PostPosted: Mon Apr 06, 2015 4:11 pm
No but it will free up the linkage by removing the load, if any.
[ps if you have a head-on like my son did, the hinges broke- it DID remove the door from the `burst proof lock!] :lol:
