It is probably the rocker arm on the linkage that has moved, it mounts on the door handle nuts.
Removing the hinges isn't going to remove a door with a burst proof lock.
No but it will free up the linkage by removing the load, if any.
[ps if you have a head-on like my son did, the hinges broke- it DID remove the door from the `burst proof lock!]
DrMini- 1970 wasaMatic 1360, Mk1S crank, 86.6HP (ATW) =~125 @ crank, 45 Dellorto (38 chokes), RE282 sprint cam, 1.5 rockers, 11.0:1 C/R.
