It is currently Fri Jul 18, 2025 11:56 pm
PostPosted: Thu Apr 16, 2015 5:26 pm
I've found the motivation to get one with getting things done on my mini again. Though I'm at a dilemma with a lightweight bootlid I've got l don't know what the best way is to install a seal/rubber.
Does anyone have any suggestions, I'm not keen on drilling holes in it for the clips etc but if l have to l will.
Is it a rover bootlid?
Is there a self adhesive rubber which would be suitable?
Any suggestions are appreciated.
1993 R32 Nissan Skyline GTR
PostPosted: Thu Apr 16, 2015 5:49 pm
Fit a seal around the boot opening and not to the boot lid, like a door seal.
PostPosted: Thu Apr 16, 2015 6:36 pm
Very good idea, any idea on a suitable seal?
PostPosted: Thu Apr 16, 2015 6:52 pm
Either use a modern Rover seal around the body edge type... or just glue the Oz style one onto the lid itself.
Cheers, Ian
PostPosted: Thu Apr 16, 2015 6:55 pm
Something like this around the boot opening?
http://www.clarkrubber.com.au/epdm-boot ... -10mm.html
PostPosted: Thu Apr 16, 2015 7:08 pm
Yep, that's the sort of thing. See if you can get a short sample and then try it out.
Hopefully the boot will close no matter where you fit the sample to the body.
Test the seal is sealing by closing a sheet of paper between the boot lid and the seal and then pull the paper to test how much grip the seal has.
PostPosted: Thu Apr 16, 2015 7:59 pm
Quality, thanks
PostPosted: Thu Apr 16, 2015 10:09 pm
The newer Rover boot seal (CKE10018) that is fitted to the body not the bootlid is available from Karcraft (and probably other mini parts suppliers)
PostPosted: Thu Apr 16, 2015 10:10 pm
I think a Rover seal on body would suit your lid best.
But if you decide to glue the original style sponge seal to the bootlid, Selleys KwikGrip contact cement works fine. I used the gel one, it's less runny.
Watch out for the sponge though, many aftermarket ones are very hard.
I used one from Minisport after buying and trying 2 others.
Here's what to look for- scroll down to the comparison pic.
http://minisport.com.au/mini-boot-lid-s ... -soft-seal
John Smidt or Karcraft would have similar soft ones now I think.
PostPosted: Fri Apr 17, 2015 8:54 am
Thanks 1071, womble and doc l will try karcraft today.
PostPosted: Fri Apr 17, 2015 9:30 am
All sounds like too much trouble Dave, I'll come around this arvo and take it off your hands for you, because I'm helpful like that ;)
PostPosted: Fri Apr 17, 2015 9:52 am
Get in line mate!
:mrgreen: :lol:
PostPosted: Sat Apr 18, 2015 9:11 am
The Mini King
PM Sent
PostPosted: Sat Apr 18, 2015 8:52 pm
Ha nice try Chux, l ended up purchasing a rover seal, unfortunately it fouls and prevents me closing the boot, l will try Clark rubber tomorrow.
PostPosted: Sun Apr 19, 2015 9:31 am
I used silastic to bond the original rubber to the boot lid of an 850 in 1996 and it was still perfect in 2012 when I sold the car, if you do it this way it will look factory and not leak.
The original clips are fiddle and a can cause rust.
