It is currently Mon Aug 04, 2025 1:33 am
 Post subject: Brakes yet again
PostPosted: Tue Jul 19, 2005 4:52 pm
I have just fitted Cooper S front brake to my mini. They work real good going backwards but going forwards they are a bit weak. They have new pistions, seals and pads in them. I am fairly sure I have got all the air out the system as I have a good pedal but could be wrong.
As anyone struck this before or got any info that may help.
Pete
PostPosted: Tue Jul 19, 2005 4:54 pm
Are the calipers bolted on the right way (as in... facing the front of the car, or facing the back of the car).
Is it possible to put them on the wrong way? I *think* it is.
PostPosted: Tue Jul 19, 2005 5:08 pm
They are set up the right way ie: Calipers on front and the bleed nipples to the top.
Pete
PostPosted: Tue Jul 19, 2005 5:16 pm
clearly the discs are on the wrong way, swap them over to the other side and try that :lol: :lol: :lol:
78 Leyland Mini - Prince
 Post subject: brakes
PostPosted: Tue Jul 19, 2005 5:23 pm
Have you fitted a brake booster, if not the pedal pressure will be high, the difference going backwards is that the rear brakes are stopping you and going forward its the fronts, have you changed the rear brakes cylinders for the smaller bore as fitted to the "S"
 Post subject: Re: brakes
PostPosted: Tue Jul 19, 2005 5:29 pm
feralsprint wrote:
Have you fitted a brake booster, have you changed the rear brakes cylinders for the smaller bore as fitted to the "S"
No to both.
Will the differnt rear wheel cylinders make much difference?
Pete
PostPosted: Tue Jul 19, 2005 5:49 pm
Yes! your back brakes will lock up before your front brakes do, hence you are now probably braking with your rear brakes only.
Cooper S rear wheel cylinders $23 each from karcraft
Discs need a lot more pedal pressure, which is why they are usually boosted.
Personally I prefer un-boosted, as you get more feel.
You will get used to "standing on the brakes"
And yes, the trouble with std rear cylinders is that when you put enough pressure to work the disks (boosted or not) the rears might lock up! Only other choices are:
a) back the rear brakes off a little so they don't work properly :shock:
b) fit an adjustable bias proportioning valve
I know which I'd do :wink:
Mike
PostPosted: Tue Jul 19, 2005 5:50 pm
The original S setup used the smaller rear cylinders and a limiter to reduce the rear wheel lock up under heavy braking, this was done because the booster increased pressure in the system while pedal presure was reduced. Without the booster the pedal presure will be high and I hope you have changed the master cylinder for a disc brake one, to many years working on BMC product lol
PostPosted: Tue Jul 19, 2005 5:52 pm
Just ask for front cylinders for an early 850 single leading shoe front, same cylinder and most places charge less for them
PostPosted: Tue Jul 19, 2005 6:52 pm
hey i am about to re do some disc brakes, do you really need a new master cylinder? i thought they were the same.... and when someone said you need alot of pedal pressure. i thought they were supposed to be better then drums!
Potato
PostPosted: Tue Jul 19, 2005 6:57 pm
They are better than drums, not because the pedal feel is any better, but because they are self adjusting (when braking heavily you won't get sideways because one side grabs before the other esp in the wet) and they don't fade like drums do.
With drums you can stop well... for the first 10 mins then it fades and gets spongy. Every week or two you have to adjust them with a spanner...
Hey if you don't like S brakes, I'm more than happy to take them off your hands :wink:
PostPosted: Tue Jul 19, 2005 7:01 pm
no its ok, i will keep them!!!!!, ok so i understand now, i am going to brands hatch now, goodbye :)
Potato
PostPosted: Tue Jul 19, 2005 7:16 pm
If you've just fitted them, maybe the pads are not bedded in yet. And choice of pad makes a lot of difference if running unboosted.
I run EBC Blackstuffs on Barney (wife's car) and Greenstuffs on mine. No servo on either.
Hers stops better in normal driving, with less pedal effort, but they fade pretty easy if you push it..
The Greenstuffs are great, when warmed up, for hard driving or on the track- but not so hot the 1st few stops. :cry:
You pays yer money and makes yer choice... :wink:
 Post subject: master cylinders
PostPosted: Tue Jul 19, 2005 8:37 pm
there is a small difference between drum brake and disc brake cylinders, basically they are the same but in the drun brake cylinder there is an extra seal to stop the return of fluid back to the tank, drums rely on the springs inside the brake drum to pull the linings back when you take your foot off the brake pedal and without the return stop you would be pumping your brakes for every stop, if this function is not removed with discs it will cause the brakes to drag and can cause them to lock on. It is just one seal that has to be removed and its not only mini's that it effects, any car being changed from a drum sytem to discs ( early holden, fords anything) can suffer from this
