It is currently Sat Jul 19, 2025 6:47 am
PostPosted: Wed May 20, 2015 6:46 pm
Hi all
I'm hoping to swap out my 2 pod instrument cluster for a 3 pod when I begin to put the clubby back together. Are there any complicated modifications required to do this?
Thanks.
Eiles
PostPosted: Wed May 20, 2015 8:04 pm
as long as you have the 3 pod mounting bracket it should all fit the same, as the 3 pod bracket uses the same holes as the 2 pod. If your lucky you might have the " white " wires for the tacho already in the loom. But I'm not sure as to what year they included those wires in the stock loom.
PostPosted: Wed May 20, 2015 8:15 pm
Thanks for info.
Will look check out the loom.
PostPosted: Wed May 20, 2015 9:46 pm
Clubby tachos are rubbish now, after 40 years their needles jump all over the place. Weren't great even when new! :lol:
I would keep your 2 clock dash, and stick a decent tacho next to it. Like the AutoGage 2300 I just bought. $134 delivered.
Last edited by drmini in aust on Thu May 21, 2015 8:45 am, edited 1 time in total.
PostPosted: Wed May 20, 2015 10:11 pm
Don't tell me the FIAT tacho finally died Doc?
PostPosted: Wed May 20, 2015 10:23 pm
I'll keep that in mind.
Cheers Doc
PostPosted: Wed May 20, 2015 10:28 pm
It recently started behaving like a Clubby one. Nil damping, so effing useless.
Mind you, was fine until now, and it was only 43 years old... haha
I'll eBay it along with the matching speedo, temp acqua, benzina and press olio gauges. :idea:
PostPosted: Thu May 21, 2015 8:04 am
Dr is spot on my clubby tacho bounces like a West Indian fast bowler !!!
1972 Leyland Mini Clubman
2000 Honda CBR929RR
PostPosted: Thu May 21, 2015 6:17 pm
My taco is fine, I've had it in there for about 8 years or so. I believe I may have had it serviced at a local instrument shop when I brought it. but I like it.
I modified a 2 pod mounting bracket to hold the 3 pod. You need to cut off the lower arms and cut n bend some more steel to hold the wider 3 pod base but the top mount is the same.
PostPosted: Thu May 21, 2015 7:45 pm
Ok. I'll go with the 3 pod.
Thank you all for advice.
PostPosted: Fri May 22, 2015 9:09 am
I have some spare 3 pod brackets
PostPosted: Fri May 22, 2015 10:33 am
I love it when the Doc talks Ialiano :D 8) :oops:
PostPosted: Fri May 22, 2015 3:02 pm
Thanks Micool. I have the bracket now but good to know in case I stuff it up when fitting.
Eiles
PostPosted: Sun May 24, 2015 6:05 pm
It amazes me that people give something a "name" because they had one that failed. God knows how much it had been mistreated in 40 odd years. There are plenty of good ones still around more than so called failed ones.
"Let us remove your "SHORTS"
PostPosted: Sun Jun 21, 2015 3:45 pm
Slight problem...
Because the 3 pod doesn't have a speedo I'm going to use the speedo from the 2 pod. Unfortunately, the hole on the 3 pod housing is about 5mm smaller and the speedo mechanism won't fit through. Is there an issue if I (carefully) grind out a bigger hole to fit?
Any advice appreciated.
Eiles
