It is currently Mon Jul 28, 2025 10:41 am
Post new topic Reply to topic  [ 104 posts ]  Go to page 1, 2, 3, 4, 5 ... 7  Next
PostPosted: Sat Jun 06, 2015 7:54 pm
Hi guys and gals
After purchasing my first ever Mini a month ago, I have just done the unthinkable a fortnight ago and also purchased a whole HEAP of parts which come with the purchase of a couple of spare engines.
Would be extremely helpful to me, and I'm sure insightful for future first time Mini owners if I could gradually post some photos of all the spare parts acquired with the idea that the long term Mini owners of this wonderful forum can help me ID what model/yr all the parts belong to?
First up a quick pick of my 75 Mini Clubman, very proud still :D
All up I picked up about 20 of these crates full of spares which included a 998 & 1098 engine/box, panels, grills, glass, speedo's, switch panels, rims, pumps, starters, alternators, manifolds, carbies, steering wheels, etc, etc.
So, if you don't mind I will start by posting up a couple of photos with numbers attached to the pics to help with the ID and to pinpoint what year/model all the parts belong to. Hopefully this turns out to be a bit of fun and I/we can learn a bit along the way!
First up......
1. Radio. yr, model?
2. Heater units? What were these fitted to?
Hope this ramble makes sense? If it does, lots more photos to come for ID.
PostPosted: Sat Jun 06, 2015 8:26 pm
You did well with all those parts, cool looking mini too.
2a is an under-bonnet fresh-air heater fitted to mini matics (round nose mini's)
PostPosted: Sat Jun 06, 2015 10:16 pm
1A is an AWA Diamond Dot radio from the 60s.
2A is like Bubba says, a Matic/Deluxe fresh air heater.
2B looks familiar, it might be an accessory heater for a truck. Do you have a photo of the other side?
PostPosted: Sun Jun 07, 2015 7:51 am
2B I think goes under the dash there is a slide door on them I have one somewhere in my shed it came out a 69k just can't quite remember whether it had something to do with the demister box on the drivers side as well not sure if the standard or a option etc
PostPosted: Sun Jun 07, 2015 9:14 am
Thanks Bubbacluby, Morris 1100 & Goldbrocade. That's great!
PostPosted: Sun Jun 07, 2015 9:16 am
Does this help?
PostPosted: Sun Jun 07, 2015 11:05 am
Kind of helps, see it doesn't have a fan, it need to be mounted over an air vent to provide flow.
Minis don't have vents!
PostPosted: Sun Jun 07, 2015 12:43 pm
Rover Cooper
ram air heaters were definately an expensive extra, here is the proof.:-|
I think it was about $45 fitted as the optionable extra, in 1969.
PostPosted: Sun Jun 07, 2015 1:24 pm
2A was also used on 850s.
Cheers, Ian
PostPosted: Sun Jun 07, 2015 2:01 pm
Thanks again Morris 1100 plus Davo111 & 1071 S.
I'll post a couple more for this arvo.
PostPosted: Sun Jun 07, 2015 2:10 pm
3. Bush of some sort?
4. Moke flares front and rear. Did these fit all mokes made - yr? Factory or optional fit?
5. Aftermarket tubing? Is this a Mini part?
6. Moke seat cushions?
Thanks for looking :D
PostPosted: Sun Jun 07, 2015 4:01 pm
3a Tie rod rubbers (Front suspension) plus associate washers and nuts
4a Yes, Moke guards, but nut sure about the fitting dates and models...sorry
5a Clubman fresh air intake, fitted to the drivers inner guard to take air in from behind the grill then through a flexible duct to the cabin for the heater
6a Moke seat cushions
PostPosted: Sun Jun 07, 2015 4:43 pm
5A,,, duckting for air to scoop from under the bonnet , fits into drivers side inner mudguard, to
then fit conssetina tubing to go through the back end of the inner guard, 90deg into the car cabin
then onto anothe rpiece of conssetina tubing & then onto the heater in clubby & Leyland minis
PostPosted: Mon Jun 08, 2015 9:01 am
Thanks Mick and TheMiniMan
PostPosted: Mon Jun 08, 2015 9:16 am
Few more for today, thanks for everyone's input :wink:
7. Asst Steering Wheels
8. Head lights......
9. More head lights, models..... They all look the same. Were these fitted throughout the Classic Mini life?
10. Starters - looks to be slightly two different numbers, design! Difference? Models?
11. Generators??, alternators, distributers
Thanks for looking.
