It is currently Wed Jul 09, 2025 11:13 pm
PostPosted: Sun Sep 13, 2015 6:33 pm
Hi all,
I have labelled these photos I took of my HIF44 carby. Could you please confirm for me what I should connect to each pipe (note 'A' is blanked off).
I have searched on this and other forums, however my carby appears to be different. On my carby 'A' is blanked off as shown. When I have searched online I have found that people refer to this as the place that the fuel in should go. Any help appreciated ta.
Morbo
PostPosted: Sun Sep 13, 2015 7:49 pm
2 is the fuel line, with A being the exact opposite side to 2. The carb can be set up from the factory with left or right side fueling, the opposite side is simply blanked.
1 is for the choke cable.
B is the breather (goes to the fuel tank on late minis)
C is crank case ventialtion
PostPosted: Sun Sep 13, 2015 8:02 pm
Awesome thanks Mick, champion!
PostPosted: Tue Sep 15, 2015 11:13 am
Twice I have connected the fuel line to B instead of 2 and wondered why the bastard flooded and would not run!
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Tue Sep 15, 2015 11:26 am
Yep - that's what I had done before I asked :D
Engine started by the way. Fuel in 2. Attached an empty fuel line in B just for a breather/overflow and blocked off the crankcase vent.
Vid of the magic moment is in the thread in my build thread below btw :)
PostPosted: Tue Sep 15, 2015 11:31 am
Good stuff. I did the same as you but I plumbed B into the air filter. It prevents dust getting into the float bowl.
Brett Nicholson
1966 Austin Mini
1973 LR Series 3 88
PostPosted: Tue Sep 15, 2015 1:29 pm
Ah cool. Yeah I might do that when I install the engine into the car. Actually, given I will be running an electric fuel pump, should I use that as a fuel return line?
PostPosted: Tue Sep 15, 2015 1:33 pm
No, its just a vent or breather, not a return line.
You don't need a return line to run an electric pump. Just make sure the pump you buy delivers the right pressure and no more than that. 3 or 4psi I think it was - best to check. Too much pressure and the needle and seat will stay open and the carb will flood.
Brett Nicholson
1966 Austin Mini
1973 LR Series 3 88
PostPosted: Tue Sep 15, 2015 5:18 pm
I think you will find B is already plumbed into the air filter, you can see the casting passage pointing backwards in the image as well as straight down. The point still stands for dust protection however, I just use a little rubber cap you can get from the bolt rack at supercheap etc with a drop of superglue on it to help it bond a little bit better. They have a tendency to get knocked off otherwise.
PostPosted: Tue Sep 15, 2015 8:59 pm
Thanks for that, will do.
Mick wrote:
I think you will find B is already plumbed into the air filter, you can see the casting passage pointing backwards in the image as well as straight down...
So it is...thanks for pointing that out cheers.
