It is currently Sat Aug 16, 2025 5:17 am
PostPosted: Sun Sep 13, 2015 6:33 pm
Hi all,
I have labelled these photos I took of my HIF44 carby. Could you please confirm for me what I should connect to each pipe (note 'A' is blanked off).
I have searched on this and other forums, however my carby appears to be different. On my carby 'A' is blanked off as shown. When I have searched online I have found that people refer to this as the place that the fuel in should go. Any help appreciated ta.
Morbo
PostPosted: Sun Sep 13, 2015 7:49 pm
2 is the fuel line, with A being the exact opposite side to 2. The carb can be set up from the factory with left or right side fueling, the opposite side is simply blanked.
1 is for the choke cable.
B is the breather (goes to the fuel tank on late minis)
C is crank case ventialtion
PostPosted: Sun Sep 13, 2015 8:02 pm
Awesome thanks Mick, champion!
PostPosted: Tue Sep 15, 2015 11:13 am
Twice I have connected the fuel line to B instead of 2 and wondered why the bastard flooded and would not run!
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Tue Sep 15, 2015 11:26 am
Yep - that's what I had done before I asked :D
Engine started by the way. Fuel in 2. Attached an empty fuel line in B just for a breather/overflow and blocked off the crankcase vent.
Vid of the magic moment is in the thread in my build thread below btw :)
PostPosted: Tue Sep 15, 2015 11:31 am
Good stuff. I did the same as you but I plumbed B into the air filter. It prevents dust getting into the float bowl.
Brett Nicholson
1966 Austin Mini
1973 LR Series 3 88
PostPosted: Tue Sep 15, 2015 1:29 pm
Ah cool. Yeah I might do that when I install the engine into the car. Actually, given I will be running an electric fuel pump, should I use that as a fuel return line?
PostPosted: Tue Sep 15, 2015 1:33 pm
No, its just a vent or breather, not a return line.
You don't need a return line to run an electric pump. Just make sure the pump you buy delivers the right pressure and no more than that. 3 or 4psi I think it was - best to check. Too much pressure and the needle and seat will stay open and the carb will flood.
Brett Nicholson
1966 Austin Mini
1973 LR Series 3 88
PostPosted: Tue Sep 15, 2015 5:18 pm
I think you will find B is already plumbed into the air filter, you can see the casting passage pointing backwards in the image as well as straight down. The point still stands for dust protection however, I just use a little rubber cap you can get from the bolt rack at supercheap etc with a drop of superglue on it to help it bond a little bit better. They have a tendency to get knocked off otherwise.
PostPosted: Tue Sep 15, 2015 8:59 pm
Thanks for that, will do.
Mick wrote:
I think you will find B is already plumbed into the air filter, you can see the casting passage pointing backwards in the image as well as straight down...
So it is...thanks for pointing that out cheers.
Users browsing this forum: No registered users and 341 guests
