It is currently Mon Jul 21, 2025 3:51 pm
 Post subject: Stiff Window Winders
PostPosted: Sun Sep 13, 2015 6:20 pm
Anyone know why the operation of window winders become so stiff.... and how do you fix it?
is it just a matter of replacing the regulator?
Jenk.
 Post subject: Re: Stiff Window Winders
PostPosted: Sun Sep 13, 2015 6:24 pm
It is most likely to be the 40 year old grease gumming the regulator up.
Try a squirt of WD40 to free it up but the real solution is to remove the regulator, clean off all the old grease and apply fresh grease.
I recently had the same problem on my Morris 1100, they use very similar regulators.
PostPosted: Sun Sep 13, 2015 7:44 pm
Awesome thanks Morris
Jenk.
PostPosted: Sun Sep 13, 2015 9:37 pm
Dry and dirty rubbers and runners can also hinder the operation. Dry lube works well.
PostPosted: Sun Sep 13, 2015 9:58 pm
Or silicon spray in channel.
