It is currently Fri Jul 18, 2025 6:59 pm
 Post subject: dash lights
PostPosted: Sun Sep 13, 2015 8:19 pm
Hi everyone, playing with the lights today, I have reont lights, highbeam, but no dash lights. Oil, high beam ant alt lights all work, is just thelights on the dash at night which dont light up. Any idea what I should look for? Have turned park light things both ways to make sure it wasnt that.
Steve
 Post subject: Re: dash lights
PostPosted: Sun Sep 13, 2015 8:21 pm
Have you tried bypassing the dimmer switch near your right knee
PostPosted: Sun Sep 13, 2015 8:27 pm
Apologies for the slight diversion - what does the dimmer switch look like? What models what is fitted to?
PostPosted: Sun Sep 13, 2015 8:34 pm
Mine is a plain 1977 Leyland and has this under the lower parcel shelf in front of your right knee.
http://www.ebay.ie/itm/Vintage-Lucas-Rh ... 41991fe9a2
PostPosted: Sun Sep 13, 2015 8:35 pm
I tried turning it, is it just a matter off joining the two wires?
Steve
PostPosted: Sun Sep 13, 2015 8:46 pm
I would check one wire has power then touch them together quickly to see if the lights come on.
It should be ok to plug them together. There may be a double terminal to plug them both into at the back of the switch. You may need to get another one if going for a roadworthy as it was an ADR thing.
PostPosted: Sun Sep 13, 2015 8:47 pm
thanks for that, I think I need to get me an electrical tester!!!
PostPosted: Sun Sep 13, 2015 8:51 pm
For $20 you will get your money's worth out of one.
PostPosted: Sun Sep 13, 2015 8:53 pm
just bought on ebay :-)
PostPosted: Sun Sep 13, 2015 9:03 pm
I do a lot of online shopping. Just not worth the $15 in fuel to go to the nearest shopping centre.
What one did you buy. Like this
http://www.ebay.com.au/itm/LCD-Digital- ... 3f42e99ecd
PostPosted: Sun Sep 13, 2015 9:06 pm
My 74 has one if dougs after dates
From the mini king parts book now mini kingdom online
Page 210 item 10 part number 13h9027 add a s at the end if second hand wanted
PostPosted: Sun Sep 13, 2015 9:09 pm
1978 LS's have them as well
PostPosted: Sun Sep 13, 2015 9:15 pm
I thought all Clubbies/Leyland Mini had them?
PostPosted: Sun Sep 13, 2015 9:31 pm
And its in the owners manuals for both non pollution gear and before non pollution gear minis
PostPosted: Sun Sep 13, 2015 9:32 pm
Yeah they did
