It is currently Fri Jul 25, 2025 12:59 pm
 Post subject: rebuilding su's help?
PostPosted: Tue Jul 26, 2005 2:49 pm
I'm just wondering if there is any trick with getting the jet bearing in the centre? I position it in the centre but it then moves to the side when I tighten the nut.. Do I just have to keep trying, or is there some trick to it? I've done one carby already and I think I got it pretty centre, but this second one is really hard..
JAM??? :D :D
PostPosted: Tue Jul 26, 2005 3:06 pm
h0nk wrote:
JAM??? :D :D
:lol: I didn't go there.....
replaced / renewed everthing except that.
PostPosted: Tue Jul 26, 2005 3:28 pm
haha stupid me.. should have left it alone, ah well I'll just try getting it as centre as possible
PostPosted: Tue Jul 26, 2005 3:44 pm
Manual tells you how - you do have a manual?
David L
PostPosted: Tue Jul 26, 2005 6:55 pm
I've completely stripped mine down and polished the whole thing lately and found that with mine I just had to be careful that I held it central when doing up the nut. Just be patient and hopefully it will work out for you. My problem is that I have had the dash pots chromed and now the plunger is sticking. Damn thing. :x
Ziff
PostPosted: Wed Jul 27, 2005 8:58 am
I bought chrome dashpot COVERS for JAM.... :wink: $30 for the pair.
PostPosted: Wed Jul 27, 2005 9:04 am
JAM what oil did you use for the dash pots.
Pete
PostPosted: Wed Jul 27, 2005 1:25 pm
Dash pot covers to suit 1 1/4 in or 1 1/2 in SU's???? Ive seen the 1 1/2in ones but never been able to get the 1 1/4 in covers!
PostPosted: Wed Jul 27, 2005 1:38 pm
Yep you can get em for 1.25's I have a pair of red covers :)
PostPosted: Wed Jul 27, 2005 1:59 pm
Pete, I used 20/50 Castrol motor oil.
The dashpot covers I got are 1 1/4". UK ebay - $30 / pair NEW, landed on my door :D Very BLING! 8)
PostPosted: Wed Jul 27, 2005 2:04 pm
Thanks for that
PostPosted: Thu Jul 28, 2005 12:30 am
Put the jet in and then assemble the dash pot and piston/needle assembly onto the carby. Lift and drop the piston and then tighten up the jet. After this the piston/needle assembly should fall to the jet with no hesitation.
Chris
Everything I like is either
