It is currently Sat Jul 19, 2025 2:55 am
Post new topic Reply to topic  [ 35 posts ]  Go to page 1, 2, 3  Next
 Post subject: Home Made Door Trims
PostPosted: Mon Jun 28, 2004 7:58 pm
Hi Guys,
Just wondering whether any of you guys can give me the measurements on a door trim from an 850, thinking of making them myself to save a bit of money.
PostPosted: Mon Jun 28, 2004 8:12 pm
They aren't square/rectangular, are they? I would recomend you get an original one, no matter the condition, and use it as a template. You got either of the original ones?
PostPosted: Mon Jun 28, 2004 8:13 pm
I made mine by using the old one for a template then trimming it till it fitted. Then skinned it.
Ok - so it's a work in progress.
PostPosted: Mon Jun 28, 2004 9:42 pm
Hi there,
I can help, i just spent a weekend fabricating new door cards for my Delux. I used a piece of cardboard ($1 approx or in my case free), cut it to size and used it as a template. The good thing is you can flip it to fit into the other door as it is a mirror image. I drew the outline on a piece of malamite board (5mm type with one side painted $15 from Bunnings) and cut it out with a jigsaw.
Then filed the corners, marked the holes for window winders etc and bob's your uncle. Now I am making groovy vinyl to cover the cards, you can get this from Clark Rubber for around $14/metre in all colours.
Be careful as my doors were not exactly the same, if you are anal like me and want a good fit then fabricate separate cardboard templates for each door.
Hope that helps you out.
Chong
PostPosted: Tue Jun 29, 2004 7:33 pm
I believe the 850 door cards are different to Deluxe ones as they don't have holes for window winders or door handles and they don't have the cutout at the top corner for the door latch.
Anto.
PostPosted: Sat Aug 21, 2004 3:27 pm
Hey Chong...
I am about to embark on the same process with my 68 Deluxe... I have the cardboard, I have the vinyl, I have the time and patience... now.... what glue did you use to stick the vinyl to the wood..?? :D
PostPosted: Sat Aug 21, 2004 3:36 pm
mate actually youll need his mum-sitting-on-her-sewing-machine
ive got a mum-on-as-ewing-machine at my place too, would like to borrow her?
Inconspicuously Conspicuous
PostPosted: Sat Aug 21, 2004 3:44 pm
I am not sure if I need your mother at this stage...I wanted to do the doors in one piece vynyl so no stitching required. I am presuming thats what you meant...
Otherwise if she can cook, clean and do ironing.. maybe I can borrow her for a bit.. ha ha
:lol:
PostPosted: Tue Aug 24, 2004 10:03 am
Spray on contact adhesive
PostPosted: Tue Aug 24, 2004 11:37 am
We used this stuff when re-trimming my brothers RX7 door trims and it was nothing short of shithouse :lol:
We ended up using qwik grip from memory.......worked a treat and those door trims are goin nowhere.
[Maverick] 1971 Mini K
PostPosted: Tue Aug 24, 2004 12:27 pm
I had no problems - just used as directed
Spray on - both surfaces - leave to get tacky before bringing thenm together - weight down so the surfaces are under pressure and leave for couple hours.
It's not as though the door card trim is under any great strain normally
PostPosted: Tue Aug 24, 2004 12:31 pm
yeah that stuff's awesome....a few mates and i used to use it to make fakies ....worked a treat....never got busted either :lol:
play 3d car games for free
PostPosted: Tue Aug 24, 2004 5:08 pm
fakies ..??
Where do you put them on a Mini..?? :?
PostPosted: Tue Aug 24, 2004 5:35 pm
dont use mdf! i di that with mine and they tend to warp a bit! but they still look sweet as!
if u were at MINISHOW u prob woulda seen em!
Rohan
1964 MORRIS 850 - POST ZOMBIE APOCALYPSE CAFE RACER INSPIRED.
https://spotify.link/D0P4KtIP2yb
1098 +0.40
266 Kent Cam
GR Flat top pistons
HS6
1.3:1 Roller tip rockers
Stupid high CR
PostPosted: Tue Aug 24, 2004 7:49 pm
Its a shame that mdf is the cheapest alternative. I had the "brilliant" idea of using perpex, but at $60 a sheet for EACH door and for each rear part, I thought that the budget could do with a more relaxed $6 a sheet in total for mdf...
: D
